97 mercades benz C280, wont stay running - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-19-2010, 02:52 PM Thread Starter
Date registered: Mar 2010
Issue, 97 C280, car did start and idle, most of the time it idles good and some times it was like a misfire, yesterday all it would do is start, idle up like normal then die. I have misfire codes for 2,3,4,5 cyl, I swapped the coil for 1&6 with 2&5, didn't change, I put plugs in it also. Fuel pressure is good, it also has a lean code but I couldn't locate a vacum leak. I have been told to put in a mass air flow but it seems to check out ok on a scan tool, any help??
whitemonte is offline
post #2 of 2 (permalink) Old 03-19-2010, 05:34 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Better question for your car's native forum. Search around or ask this on the W202 forum, you'll find it in the sedans section. Goos luck and welcome to BW.
Musikmann is offline
    86 300E DIES. WONT STAY RUNNING superheat1 W124 E,CE,D,TD Class 2 03-14-2010 02:11 PM
    2000 ml320 wont stay running please help Benbuilt4u W163 M-Class 5 11-12-2009 12:15 AM
    2.3 wont start or stay running Tommytwotone W201 190-Class 19 08-10-2009 10:58 PM
    HELP ml wont stay running... canadaml General Mercedes-Benz 3 05-21-2007 05:13 PM
    89 190e that wont stay running!! mercedesgirl W201 190-Class 2 09-26-2006 05:55 PM
