ignition is locked - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-18-2010, 01:29 AM Thread Starter
Date registered: Mar 2010
ignition is locked
The ignition is locked. The key won't turn. Any suggestions?
mimom710@aol.com is offline
post #2 of 7 (permalink) Old 03-18-2010, 01:38 AM
Ox8xO's Avatar
Date registered: Jul 2009
Vehicle: W164
I have one - fill out your profile. We can't read minds to find out what you drive.
Ox8xO is offline
post #3 of 7 (permalink) Old 03-20-2010, 06:26 AM
Date registered: Jan 2010
I also had this trouble and it was due to battery completelly drain out. After a new charge everything runs fine.
grasnall is offline
post #4 of 7 (permalink) Old 03-20-2010, 03:39 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Need more info.
Musikmann is offline
post #5 of 7 (permalink) Old 03-20-2010, 04:49 PM
In my case, when I opened the driver's door, I noticed that internal lights did not fired on and the panel was completely dark. So, I assumed that there was a battery issue. For more info I guess do with other one suggested : inform the model of your car in order that anyone may help you. Regards.
grasnall is offline
post #6 of 7 (permalink) Old 03-20-2010, 04:52 PM
mR SHaDoW's Avatar
Date registered: Mar 2009
Vehicle: euro 1985 mercedes 190e 2.3-16v,1992 Mercedes 190E 2.6
try turing steerin wheel and turning key at the same time............ if it is wat i think it is good luck need more info
mR SHaDoW is offline
post #7 of 7 (permalink) Old 03-20-2010, 07:35 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Suicide.
flyboyike is offline
    ignition locked fad2blac2 W126 S,SE,SEC,SEL,SD,SDL Class 3 02-23-2010 07:12 AM
    Ignition Lock Locked Tumbler tgordy41 W126 S,SE,SEC,SEL,SD,SDL Class 9 08-03-2009 05:30 PM
    Ignition Swith Locked Up ! Rseegars R170 SLK-Class 5 01-11-2008 06:52 PM
    Locked Steering Wheel and Ignition truviking W201 190-Class 6 09-23-2006 09:01 PM
    HELP!! J REG MERC 190 IGNITION LOCKED!! Guest (MBNZ) W201 190-Class 7 04-24-2002 02:32 PM
