Bench Testing Fuel Pump - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-15-2010, 02:48 PM Thread Starter
Date registered: Mar 2010
Application: 1984 190E 2.3 W201
Shouldn't an electric fuel pump build up enough pressure to squirt gas past the check valve at the exit end of the pump when bench testing? The check valve is clean and works easily. I have fuel supply to the inlet side, the pump spools up but no gas. Am I missing some action that the other components provide since the supply tube that connects the pump, filter, and accumulator is removed?
BlackVelourW201 is offline
post #2 of 2 (permalink) Old 03-17-2010, 10:08 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
bench testing antenna daryn R/C107 SL/SLC Class 3 03-22-2008 08:35 PM
Fuel pump testing olsb19 W124 E,CE,D,TD Class 1 02-25-2008 02:50 PM
testing fuel pump via jumping pins 7 and 8 william.wood W126 S,SE,SEC,SEL,SD,SDL Class 2 11-10-2005 05:47 AM
fuel air mix / testing fuel pumps and pump pressure william.wood W126 S,SE,SEC,SEL,SD,SDL Class 0 11-09-2005 11:32 AM
Bench Testing Bi-Xenons - Help Please! N1ML W163 M-Class 4 02-21-2004 12:01 PM
