VDO Light flashing on E300 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-15-2010, 03:30 PM Thread Starter
Date registered: Mar 2010
Can anyone help.
I realise that the VDO light flashing is a traction warning, and is brilliant in the wet, icy conditions at it warns you to slow down.
Trouble is this morning the light was flashing when the road conditions were fine and the temp 13 degrees! The car would not go over 35 mph without the light flashing and felt like a Deisel starvation. It happened for about 5 mins and then was fine, later in the day it happened again for 5 mins and then it was fine!
Can anyone advise please?
MercMikeMerc is offline
post #2 of 4 (permalink) Old 03-15-2010, 05:19 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
VDO is the name of the company that made the instrument cluster.
If you're talking about the triangle with exclamation point, that's indeed the traction control warning and your description sounds like a fault in the system. MAYBE gunk (road salt, e.g.) on a wheel sensor.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 4 (permalink) Old 03-16-2010, 02:36 AM Thread Starter
Thanks IKCHRIS,
If you're correct, why does the engine struggle? Or is it designed to cut the gas?
post #4 of 4 (permalink) Old 03-16-2010, 09:55 AM
Quoted: 2 Post(s)
It is.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    altenator and battery vdo light 42filip W203 C-Class 2 12-27-2009 07:16 PM
    Check engine light and flashing Low gas light benz3000 W210 E-Class 4 08-04-2009 02:17 PM
    '98 CLK 320 VDO light on the Dash Merc250c C208/A208 CLK-Class 3 07-25-2006 12:58 AM
    check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 05:31 PM
    Help Please!!! Check Engine Light...Empty Fuel Light Flashing mJstk01 R170 SLK-Class 6 05-18-2003 11:53 AM
