'02 S430 Key won't work --Help! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-14-2010, 08:04 AM Thread Starter
Date registered: Aug 2006
Last night a valet tried to unlock the passenger door-- a loud electronic squeal emitted for about 5 seconds. When I drove away the entire instrument cluster was dark. Upon stopping and restarting the car, all appeared well. This morning the key would not turn and I noticed the lights had been turned on manually and the battery was dead. after charging the battery, the key still would turn. I disconnected the battery, reconnected, left the key in the ignition for 20 minutes and still nothing. The key will work the remote features but not start the car. A second key will start the car but not work the remote features. Any Ideas? Thanks.
MKH02 is offline
post #2 of 3 (permalink) Old 03-14-2010, 11:06 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 343 Post(s)
Not quite sure what you mean here.... do you mean it will not lock/unlock the doors?
Are the batteries inside both keys OK? Does a little light show when you press any button confirming the battery status is OK.
However, you can start the car with flat key batteries, but you cannot lock/unlock the doors remotely.
keyhole is offline
post #3 of 3 (permalink) Old 03-14-2010, 12:03 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Your car is a W220 chassis. If you scroll down the forum choices, you will see a forum for the W220. That room is filled with people who have some version of the same car as you and you'll more likely find specific help there.
I have a W220, but I have never had key difficulties, so I can't offer you any suggestions.
You might also try the electronics and telematics forum.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
    Cigarette lighter S430 2004 doesnt work maximillian Alexander General Mercedes-Benz 6 05-13-2012 03:57 PM
    advice buying a 2000 S430 needs work jdsmith46 W220 S-Class 8 03-12-2010 12:56 AM
    '01 S430 Airmatic - visit work shop Christian86 W220 S-Class 4 12-27-2009 09:14 PM
    05 S430, Controls on Steering wheel and Horn do not work leeloo W220 S-Class 2 07-12-2009 07:19 AM
    S430 Trunk not opening with key or remote nEVERCLEAR General Mercedes-Benz 2 11-09-2007 09:46 PM
