MB Anti-freeze - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-12-2010, 03:22 PM Thread Starter
Date registered: Jun 2007
Vehicle: 1995 SL 500 2005 SL500
Quoted: 9 Post(s)
Post MB Anti-freeze
FYI
Lee Wireless is offline
post #2 of 11 (permalink) Old 03-12-2010, 05:47 PM
mndwgz's Avatar
Date registered: Dec 2008
Vehicle: VW CC & Wifeys 2003 SLK320
What's your opinion on adding Red Line Water-Wetter to the mix?
(Since your in the same neighborhood, and you know it's going to get hot.)
mndwgz is offline
post #3 of 11 (permalink) Old 03-12-2010, 06:28 PM Thread Starter
Quoted: 9 Post(s)
I only use what Mercedes recommends. Both of my SL run right at the recommended temperatures be it winter or summer. To each his own. I've been doing this since I bought my first 300CD in 1980.
post #4 of 11 (permalink) Old 03-12-2010, 08:56 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 386 Post(s)
Red line water-wetter definitely helps reduce temps and overheating on my off road motorcycle. Lot's of off roaders swear by it.
that said, haven't ever used it in cars, since I haven't had any that had any temp issues. I don't know exactly what is in it, but I suspect it has surfactants of some kind to provide better wetting action to metal surfaces and reduce small air bubbles from forming in hot spots.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #5 of 11 (permalink) Old 03-12-2010, 10:10 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't think it's advisable, or recommended by MB, to add anything to your coolant. Some people say Zerex makes an acceptable substitute but I'll only use the MB branded stuff with no additives.
Musikmann is offline
post #6 of 11 (permalink) Old 03-12-2010, 10:54 PM
Vehicle: 2002 E430 4-Matic
Quoted: 33 Post(s)
It's my understanding that Zerox is the OEM for Mercedes antifreeze. The only difference between G-05 and MB Brand is the dye color. (and price)
Figuero is offline
post #7 of 11 (permalink) Old 03-13-2010, 08:53 AM
Kajtek1's Avatar
Quoted: 1193 Post(s)
My 12 years old Mercedes with 200k runs cool at 102F outside even driven in the mountains.
In the past green coolant on our Volvo at lower mileage created so much build up in the radiator that I had to replace it just because of that.
$10 extra for MB coolant is still pretty cheap insurance for $800 radiator job.
Kajtek1 is offline
post #8 of 11 (permalink) Old 03-13-2010, 09:45 AM
MTI
MTI's Avatar
Vehicle: '85 2.3-16 '99 C280 '11 GLK350
Since Zerex meets MB's coolant spec, they are "some people." BTW, do you know who makes MB's coolant in the US? Have a guess.
MTI is offline
post #9 of 11 (permalink) Old 03-13-2010, 10:01 AM
Musikmann's Avatar
Quoted: 6 Post(s)
If Zerex makes it for MB then it must be O.K. You work for MB so I guess you should know. I still don't think additives should be used though. Does Zerex G-05 cost that much less?
post #10 of 11 (permalink) Old 03-13-2010, 04:49 PM
Date registered: Jan 2004
Quoted: 30 Post(s)
I talked with an engineer from Zerex a few years ago and he told me that G05 is not identical to the Mercedes branded coolant, but it is pretty darn close. I usually throw a bottle of Water Wetter in when I do a coolant change. It's purpose is not to reduce coolant temperature, but to minimize temperature spikes under load, i.e. if your car's normal temperature is 80°, it is still going to be 80° with Water Wetter. However, if you usually spike up to 100° under load or in traffic, the Water Wetter will mitigate the temperature rise. I found this to be true on my 240D. It used to climb to the upper 90's when I went up a steep incline. Now it is rock solid at 80° all the time. I contribute at least part of that change to the Water Wetter - all of it I don't know for sure.
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
    Anti freeze top up? Unpimped W163 M-Class 26 02-22-2010 02:21 PM
    anti-freeze leak ninasteel BenzWorld Help 0 12-17-2004 03:05 PM
    what could low anti freeze do to an ml ESTE W163 M-Class 5 07-10-2004 02:49 PM
    anti freeze flush snik W140 S-Class 4 12-28-2003 10:50 PM
    Wrong anti-freeze, what to do? sdgrossman1 W124 E,CE,D,TD Class 5 08-14-2003 11:06 AM
