SLK 200 - Braking not what it should be? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-12-2010, 08:14 AM Thread Starter
Date registered: Mar 2010
Hi all,
This is my first post on here, so hello to you all!!
I've had my SLK200 since Oct last year, it is a current model. Just had the car serviced and asked for the brakes to be looked over. The problem is, when braking fairly hard from, say, 60'ish, I get a feeling of 'fade' which doesn't insprire confidence. Merc have checked them and all appears well, but the feel is just not right. I drive a few cars, had 3 series BMWs and a big fan of the Toyota MR2, currently have a MK2 Rev5. Never had an issue with brakes before but the SLK does not inspire confidence, at all. Does anyone else feel the same, is it just an SLK 'thing' or should I get an independent to take a llok at it?
Thanks in advance!
Regards,
Steve
Steve_Jones is offline
post #2 of 2 (permalink) Old 03-12-2010, 03:50 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
Originally Posted by Steve_Jones View Post
Just had the car serviced and asked for the brakes to be looked over...
But what did they do? Simply glance at the pads?
If you are unhappy with your braking (and your tires are good) you should get it checked on a dynamic brake testing system, which is a rolling road. Then you get a set of readings which can be compared with the optimum values.
keyhole is online now
    Slk 200 kompressor First Problem at 200.000 km !!!!! o_Anapodos... R170 SLK-Class 4 05-30-2009 01:32 PM
    Factory SLK 32 Braking System for Sale: MLTHREEFIFTY R170 SLK-Class 6 01-28-2008 11:48 PM
    Q's !! Why does some european Slk called Slk 200? Do they have a different engine of................ Linh R170 SLK-Class 19 12-04-2007 09:48 PM
    The altitude difference of SLK 200 vs SLK 55 AMG salihyoluc R171 SLK-Class 3 09-24-2004 01:43 PM
    200 slk locomocione R171 SLK-Class 0 07-23-2004 02:24 AM
