New Member found disconnected hose under dash while replacing idlecontrol 1982 380SL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-09-2010, 07:52 PM Thread Starter
Date registered: Mar 2010
I am a new member. My wife's daily driver is a 1982 380SL. It is experiencing the high idle problem. The mechanic diagnosed the problem as the idle speed control module. I replaced it this evening. The problem is better but not perfect. When I shift into neutral or park, from drive while stopped, the RPM goes up from around 700-800 to around 1100 then drops back to 700. It is better than it was. We will need to drive it to see if this is good enough.
While replacing the module, I discovered a 1/2" or so flexible hose that was disconnected on both ends. I took some photos of the tube. See attached. I could tell where one end hooks up. It is at a plastic T that leaves the top of the heater box near the firewall. The pipe then snakes up around the air duct under the glovebox and is open behind the glove box. I didn't see a place where to hook up this end.
Any help would be appreciated.
ID:	295447   Click image for larger version
ID:	295448   Click image for larger version
ID:	295449   Click image for larger version
ID:	295450   Click image for larger version
1982_380SL is offline
post #2 of 2 (permalink) Old 03-09-2010, 10:26 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    1982 380SL dash mikecardone R/C107 SL/SLC Class 1 02-16-2010 01:26 PM
    Disconnected hose in engine compartment, where does it go? contender77 W163 M-Class 16 12-07-2009 07:23 PM
    Mystery vacuum hose disconnected khimani_mohiki W126 S,SE,SEC,SEL,SD,SDL Class 6 11-05-2009 09:31 PM
    Disconnected hose/tube benzportland R/C107 SL/SLC Class 1 10-17-2009 08:28 PM
    What vaum hose is this? I found it disconnected. soundquest W124 E,CE,D,TD Class 0 06-30-2009 01:52 AM
