380 SE TRANSMISSION PROBLEM - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-09-2010, 03:17 PM Thread Starter
Date registered: Sep 2009
Vehicle: 1983 MERCEDES 38O SE
I have a W126 380SE. I am told that although I have a four speed transmission the vehicle only uses three gears under normal driving conditions. The first gear is only used when the accelarator pedal is floored for a faster take off. If this is correct there is something wrong with my car as my first gear is constantly being used under normal driving conditions. As I have only had the car 6 months or so I naturally presumed that this was normal. Can any body help?
HENRY FIJOLEK is offline
post #2 of 4 (permalink) Old 03-09-2010, 05:08 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 405 Post(s)
Your gearbox should be a 722.3, which is a 4-speed automatic.
How do you know that it is staying in 1st (or 2nd gear)? From the rev counter? That certainly is not right and must affect your fuel consumption. However it's hard to believe that you really are driving in one gear all the time without damaging the gearbox. When was the ATF last changed?
keyhole is online now
post #3 of 4 (permalink) Old 03-10-2010, 12:49 AM Thread Starter
380SE Transmission problems
Thanks very much for the response. I think you may have misunderstood me. When I drive the car at all times the gears change through first to second to third to fourth normally. I am told however that the car should take off in second to third to fourth and will only use first gear when the accelarator pedal is floored from take off. I am unsure if this statement is correct
as the car has allways started in first then changed up through the gears normally.
post #4 of 4 (permalink) Old 03-10-2010, 02:51 AM
keyhole's Avatar
Quoted: 405 Post(s)
Henry - my apologies. You're quite right, I did totally misunderstand your post...
On the later 722.6 5-speed auto which I have, there is indeed a 'mode' switch to choose the style of driving, one of which will cause starting in 2nd gear, which is better in snow, etc. I'm not sure if that existed for your earlier system.
If you re-post your question in the dedicated W126 forum, there are plenty of guys there who own your exact model and will be able to share their experience with you.
560 same transmission as 380? marlinspike W126 S,SE,SEC,SEL,SD,SDL Class 0 10-28-2008 08:04 AM
Transmission Fluid level check 380 SE goofyguy W126 S,SE,SEC,SEL,SD,SDL Class 6 08-15-2007 11:22 PM
Transmission TROUBLE! 84 380 sl peter g R/C107 SL/SLC Class 5 09-09-2005 02:50 AM
Idle Problem with 380 SE Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 5 04-04-2002 08:25 PM
Anyone know if 85 560 transmission fit in a 380 ? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 11-14-2001 03:25 PM
