Aftermarket HID bulbs in stock HID lamps weirdness - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-09-2010, 12:04 PM Thread Starter
Date registered: Sep 2009
Vehicle: 2002 E320 4Matic Wagon
Lightbulb Aftermarket HID bulbs in stock HID lamps weirdness
One of my stock D2R OSRAM HID headlight bulbs blew recently and I found some aftermarket (Generic) HID bulbs locally for quite cheap. I replaced the burnt out bulb, started the car, turned on the lights and things seemed to work fine.
Since it's recommended to replace these bulbs in pairs, and also because the new ones are 6000K as opposed to the stock 4300K colour temperature, I changed the still working stock bulb as well. Restart the car, try the lights and the just replaced bulb doesn't light up, but the first one I replaced still does. Figuring it's a dud bulb I replace it again with the original stock which ends up working fine again.
Now here's where the weirdness begins and my real question is. In the days following I find that the new generic bulb only lights some of the time. I trace it down to the fact that first thing in the morning when I start the car the generic bulb will never light and I get a "Check Lamps" error. (btw - this is a Canadian model 2002 E320, so it has stock daylight running lights that ignite the headlights when you put it in Drive). However, if I manually turn the headlights off, wait a moment, and then turn them on again they both light up. Furthermore, for the rest of the day both lights will ignite without trouble.
A day or two of this got me thinking that the second generic HID bulb might be fine. I swap it in for the stock HID bulb, start the car, manually turn on the headlights, one headlight ignites. I then manually turn off the headlights, wait a moment and then turn them on again and now both new generic HID bulbs ignite. Again, for the remainder of the day starting and stopping the car I have no more trouble with the headlights until the next day.
The simple answer is likely that I should just stick with the much more expensive stock OSRAM HID bulbs, but I was wondering if anyone has had similar experiences and/or might have an educated guess at what's going on. I've read about problems similar to this with HID conversion kits, but this is a stock HID system.
Thanks for any help.
pdodee is offline
post #2 of 2 (permalink) Old 03-09-2010, 07:51 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Its either the cheap bulbs or a bad ballast.
mr.xpowerseller is offline
    HID Fog Lights HID Replacement Bulbs or Look a likes doktorek W221 S-Class 8 01-19-2012 07:35 AM
    aftermarket HID on all lamps pinoyk20 W210 E-Class 8 05-01-2009 06:52 AM
    aftermarket HID on all lamps pinoyk20 W210 E50 AMG, E55 AMG 0 04-30-2009 09:48 AM
    Aftermarket Xenon HID headlight bulbs? NorCalMbz W203 C-Class 2 09-29-2008 10:57 PM
    bi-xenons headlights HID($1120) __Vs__ ($9.99) HID white Bulbs ready 2 go HotGQ161 W203 C-Class 21 06-09-2004 06:00 AM
