Quick Crankshaft Position Sensor Quest... - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-09-2010, 11:52 AM Thread Starter
Date registered: Sep 2009
Vehicle: 2000 E320 Sedan
I have a 2000 E320. I was going to replace the Crankshaft Position Sensor. I'm confused on which one I need. The 1 clip or the 2 clip? I read somewhere that if your engine serial number ends in 370998, its the 2 clip. If it ends in 370999, it's the 1 clip on. My car reads 6937088. Which I found on the front of the engine.
Am I reading at the wrong place. Please help. Thank you.
GARY476 is offline
post #2 of 8 (permalink) Old 03-09-2010, 02:32 PM
Date registered: Feb 2010
I recently replaced the CPS on a friends car. I removed the connector from sensor and matched it up with the photo on the parts sellers page. The sensor I received fit the connector perfectly.
Chas H is offline
post #3 of 8 (permalink) Old 03-09-2010, 03:04 PM Thread Starter
Yeah, I was thinking about doing that. But I was wondering if anyone knew which one I needed. I wanted to buy it in advance and do everything at once.
Chas, how long did it take to replace the CPS? And do I have to do anything special to the car after I install it?
GARY476 is offline
post #4 of 8 (permalink) Old 03-09-2010, 03:18 PM
It maybe took me 5 minutes to find the CPS, get the connector off and drag it out. You can't see the sensor, IIRC. You will need a torx socket to remove the single screw holding the sensor in place. Actually replacing the sensor took another 5 minutes. But you can't see what your doing so think it all out before starting.
I did nothing after replacing the sensor and connecting it. Car ran fine and the hot no-start was cured.
Chas H is offline
post #5 of 8 (permalink) Old 03-09-2010, 04:27 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
Gary - different model, but the same engine as yours, M112 V6.
PeachPartsWiki: R&R of the Crankshaft Position Sensor
keyhole is online now
post #6 of 8 (permalink) Old 03-09-2010, 07:33 PM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 11 Post(s)
Go to startek epc, put your vin in, and it will show what you need for your car. Those 6 numbers they are referring to are the last 6 numbers of the vin.
Thanks!
Fred
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
http://s4.photobucket.com/albums/y145/waybomb/
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #7 of 8 (permalink) Old 03-10-2010, 12:43 AM
Date registered: May 2008
Vehicle: 1990 190E 2.3
No need for Torx - a 1/4" or 6mm socket also works.
Just did it on my 2000 ML320 - was the one clip version. Car now does not run rough intermittently like it has since brand new.
Resistance of old CPS was 1,700kohms, new Bosch one was about 1/2 this.
1990 190E 2.3 25k miles
Doug11 is offline
post #8 of 8 (permalink) Old 03-10-2010, 08:46 AM Thread Starter
Thank you....
Thank you everyone for your help. I will try to replace it this weekend and I'll let you know how it went. Thanks again.
GARY476 is offline
Cam Position Sensor Or Crankshaft Position Sensor? Ryanoscerous W210 E-Class 8 04-02-2009 04:18 PM
Crankshaft position sensor swimboydip R170 SLK-Class 2 11-14-2008 10:03 PM
Crankshaft Position Sensor deeanny W163 M-Class 4 09-26-2008 03:23 PM
FS: Crankshaft Position Sensor 3199cc C208/A208 CLK-Class 1 08-16-2008 06:33 AM
crankshaft position sensor mcavs W220 S-Class 9 04-13-2008 04:00 PM
