Check engine light comes on intermittingly - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 03-09-2010, 09:44 AM Thread Starter
Date registered: Mar 2010
Hi there. I have a 2002 ML320 and I'm having some issues. At times the engine runs smoothly and all is fine, when I'm stuck in traffic, the engine idles at 500-700 RPM and seems to sputter (for lack of a better term). This causes the check engine light to illuminate and it will stay on for the rest of the drive and will also be on when I start the car again. The next day when I start it up, it will be off and then when I'm stuck in traffic, the engile will idle rough again and the process repeats itself.
I had spoken with a few people and they said that maybe I had bad gas in the system and was told to buy octane boost and fuel injector cleaner.
I'm sorry if this has been posted before, I'm just looking for some solid advice before taking it into a shop.
Thank you, Mark.
Silver_ML320 is offline
post #2 of 5 (permalink) Old 03-09-2010, 10:00 AM
Musikmann's Avatar
Quoted: 6 Post(s)
How many miles are on your car, on the spark plugs and on the fuel filter?
Fuel injector cleaner will not hurt anything and it's worth a try (MB approves of Chevron Techron and they have a private labelled product available from dealers). I don't know what effect the octane booster will have. If you noticed your CEL right after refueling, then you can suspect bad gas. If not, then that's not it.
Musikmann is offline
post #3 of 5 (permalink) Old 03-09-2010, 10:12 AM Thread Starter
Hi Musikmann, I am flirting with 142K miles on the car right now. The spark plugs and wires were replaced 2 years ago.
post #4 of 5 (permalink) Old 03-09-2010, 11:04 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Hello back Silver ML320. We have the same engine and our fuel filters were both due at 60,000 miles or 4 years but I let mine go 8/80,000 with seemingly no ill effects. A restriction in fuel flow might explain your symptoms. Also, oxygen sensors are a common cause of a CEL and Bosch says they have a lifetime of 100,000.
post #5 of 5 (permalink) Old 03-09-2010, 07:55 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
MAF (air mass sensor)
mr.xpowerseller is offline
    Check Engine Light - How to check for codes? DesignEx W203 C-Class 2 03-02-2010 04:21 PM
    2002 c 230 check engine light and srs light upstaterider2003 General Mercedes-Benz 4 08-04-2008 07:35 AM
    1997 S420 Fuel gage light flasehs setting Check Engine light aljabari W140 S-Class 7 09-03-2007 09:19 PM
    How to check code for check engine light 94 E320 W124 Synd W124 E,CE,D,TD Class 1 05-24-2007 02:37 PM
    check engine light & flashing fuel guage light pd99sl500 R129 SL-Class 7 02-27-2005 04:31 PM
