Keyless Entry - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-07-2010, 09:01 PM Thread Starter
Date registered: Jan 2010
Keyless Entry
I just bought a 2006 CLS 500 with keyless go/entry. All doors except for the driver's door seem to work (automatically unlock when I have my key in my pocket and the pull the door handle). Any idea how much it may cost to fix the driver's door handle?
run4it is offline
post #2 of 6 (permalink) Old 03-08-2010, 08:26 AM
Musikmann's Avatar
Quoted: 6 Post(s)
It sounds like either 1 of 2 things. The mechanical locking mechanism could be binding or the vacuum/pressure hose from the PSE pump might have come loose. Take the door apart and inspect those. Can you unlock the door by pulling up on the button as it is? If so then it's more likely the PSE line. Even if you have someone else do the work, I doubt it would cost very much. Good luck.
Musikmann is offline
post #3 of 6 (permalink) Old 03-08-2010, 09:51 AM
Kajtek1's Avatar
Quoted: 1198 Post(s)
depends on what you consider very much.
My dealer charges over $200 for replacing light bulb in the cluster.
With $150/hr doesn't take much to run pretty high.
As MM said -check if inside button will operate the trouble door. If it does -the trouble would be probably on electronic side. If it doesn't simple things MM suggest are more likely. The keyless system is not popular Enoch to have too much exposure on this forum. Most of the time when you hear about it is when husband hitchhike with his wife to pick up some part and after dropping wife at the gym, he drives few miles to red light only to realize that the key is in wife's bag.
Without the key present the engine will keep on running till you stop the car
Kajtek1 is offline
post #4 of 6 (permalink) Old 03-08-2010, 01:12 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
I assume the door handle is the same part as on a W211. These are prone to fail, it would then be the KG sensor part at the handle. You would find more info from the W211 section. I cannot remember if there are DIY instructions.
Diesel Benz is offline
post #5 of 6 (permalink) Old 07-18-2011, 05:43 PM
Date registered: Nov 2004
Vehicle: 2003 E55
Mercedes dealer charged me $447.00 to replace the drivers door handle to correct keyless entry problem approx. 3 years ago. It now is doing the same thing. It seems mercedes parts are made to break so we can keep paying for the same shit.
Rocky147 is offline
post #6 of 6 (permalink) Old 07-18-2011, 08:45 PM
Kajtek1's Avatar
But look at the bright side. The dealers always wash your car with the service.
Kajtek1 is offline
    Keyless entry dgilbert@ococean.com W202 C-Class 1 01-09-2009 11:20 PM
    Keyless Entry S.M. Autoworks W124 E,CE,D,TD Class 4 04-30-2008 10:42 PM
    Keyless Entry lbc W164 M-Class 3 08-09-2005 01:28 PM
    Keyless Entry???? jtoma878 W123 E,CE,D,CD,TD,TE Class 4 06-03-2005 10:30 AM
    keyless entry Guest (MBNZ) W201 190-Class 0 03-03-2002 10:27 PM
