Synthetic or normal oil for my diesel ? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 03-07-2010, 10:57 AM Thread Starter
DAT
Date registered: Mar 2010
Just got a 1991 300D 2.5 turbo. The car is in very good condition and only has 125K. It has been running on regular engine oil and my question is due to the age of the vehicle and the mileage is there too much built up engine sludge to negate the benefits of switching to synthetic.
If the consensus is it's not too late to switch, any recommendations...I live in Atlanta, Georgia where there are somewhat mild winters and long periods of excessive heat and humidity. Thanks
DAT is offline
post #2 of 3 (permalink) Old 03-07-2010, 05:46 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Ask a dealer what oil they recommend for your car. My feeling is if it has always been running conventional oil then stick with that and the specifications (or the current equivalent) that the owner's manual tells you to use.
Musikmann is offline
post #3 of 3 (permalink) Old 03-07-2010, 06:49 PM
Kajtek1's Avatar
Quoted: 1248 Post(s)
Its personal choice. I run synthetics even in my lawnmower. They are cheap enough and supplies much better protection than dino oils.
The only exception is my Ford diesel. It takes 15 quarts and I never drive the 5000 miles interval in one year anyway so extended run on synthetic would run me well over time limit.
Kajtek1 is offline
    Semi-synthetic or synthetic oil? MikaHakkinen R129 SL-Class 1 02-12-2009 03:16 AM
    Those running diesel-specific synthetic engine oil... mckellyb W126 S,SE,SEC,SEL,SD,SDL Class 5 03-31-2008 04:24 AM
    Synthetic oil in a diesel? Hofler W123 E,CE,D,CD,TD,TE Class 24 10-11-2007 03:00 PM
    Oils... synthetic or normal? Batou W126 S,SE,SEC,SEL,SD,SDL Class 14 09-09-2006 05:40 PM
    Your opinion on reg oil vers synthetic oil on older benz. minn500sl General Mercedes-Benz 9 11-02-2005 07:46 AM
