Confirmed: COMAND CD-ROM in drive does drain battery - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-06-2010, 04:01 PM Thread Starter
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 405 Post(s)
According to the MB WIS for my CLK, under ther topic 'Checking quiescent current consumption' I read the following:
Switch off all electrical consumers, and measure quiescent current at the battery terminals.
1. Remove transmitter/ignition key.
Items 2 to 9. Switch off various items, including COMAND.
10. Remove CD-ROM from COMAND drive.
keyhole is online now
post #2 of 4 (permalink) Old 03-07-2010, 12:24 AM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Yes but this is only from a malfunction where the device does not enter full sleep in case the DVD-ROM is inserted, even if it should. You should find advice how to fix this either from a fresh WIS or TIPS. If the related control units are fine, then the it would not matter if the DVD drive is inserted or not.
Several owners have figured out this issue and reported about it. Some consider it sufficient to take the DVD out when the car is parked (for a longer period) but this is very inconvenient and the car really should be fixed in this case.
Diesel Benz is offline
post #3 of 4 (permalink) Old 03-07-2010, 04:14 AM Thread Starter
keyhole's Avatar
Quoted: 405 Post(s)
DB - thanks for your comments.
You may well be right above, but I am very surprised if the WIS includes an instruction based on what might be a fault situation, ie, a failure to get into sleep mode. I do not have a list of those systems that are switched into sleep mode, but there must be quite a few.
You referred to DVD-ROM based Satnav. Does that behave differently (in this respect) to the earlier CD-ROM system that I have?
post #4 of 4 (permalink) Old 03-07-2010, 09:31 AM
Quoted: 39 Post(s)
Sorry, I thought you were talking about the W211 with a separate Navigation DVD drive. I remember other models having issues with Comand not entering sleep mode. You must be referring to a CLK with a CD based head unit? I have not studied that model really at all. But one cannot consider it acceptable that the CD would need to be removed when the car is parked, it isn't acceptable for any model.
Removing the CD could be a reasonable temporary solution but there must be a SW update or some other solution for a final fix, perhaps it was not available at your version of WIS?
Could the source of my battery drain be the drive-by-wire system? bboyer32 General Mercedes-Benz 3 11-13-2009 06:31 AM
battery drain ahmer82 General Mercedes-Benz 2 08-29-2009 01:13 PM
05 COMAND Disks - Parting the CD ROM Set (not DVD or ML) sbmotohead For Sale/Wanted/Trade/Giveaway 7 12-11-2006 01:43 PM
Battery Drain willieg W124 E,CE,D,TD Class 3 10-25-2004 08:55 AM
Anybody have intermittent "Error - Cannot read CD-ROM" on the Nav drive? MikeT W163 M-Class 6 04-21-2002 08:18 PM
