722.6 Transmission Oil Level Tool - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-05-2010, 09:22 AM Thread Starter
Date registered: Jan 2008
Vehicle: 2011 E350 Bluetec
Hi,
Is there anybody near Palo Alto, CA that might have the transmission tool for rent? I would rather pay someone to use it for a few minutes than buy something I would probably use once. I could measure the fluid level right away. Should only take a few minutes of your time.
Erik
ecords is offline
post #2 of 7 (permalink) Old 03-05-2010, 10:32 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Concurrent with using this tool, it is nice to have a laser temperature tool to facilitate estimation of actual temperature of the fluid. Makes a difference as to how you read the dipstick.
RTEMPB3A, Thermometer, Infrared, Laser
A bit of a "catch 22," I'd think, and suggestive that you might want to measure fluid cold. 'Cause if you think it's low or high, you might not want to drive it enough to get if hot. At least 5 liters in it according to Mercedes.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 7 (permalink) Old 03-05-2010, 01:43 PM Thread Starter
Kent,
Thanks for the advice. I was pretty careful to accurately measure the fluid removed from the transmission when I changed the fluid. I do have a laser thermometer. I just want to make sure the level is correct.
Erik
ecords is offline
post #4 of 7 (permalink) Old 03-05-2010, 03:16 PM
Kajtek1's Avatar
Quoted: 1193 Post(s)
You can use about 4 feet of 1/8" steel cable as the tool. It cost couple of dollars at HD.
We do have pictures of the dipstick scale in W210 stickies. Hope your class has the same?
Kajtek1 is offline
post #5 of 7 (permalink) Old 03-05-2010, 06:00 PM Thread Starter
I ended up using the coiled spring housing for a manual choke. Worked OK, just a bit difficult to determine oil level. I did add 400 ml.
Thanks,
Erik
ecords is offline
post #6 of 7 (permalink) Old 03-05-2010, 08:42 PM
Kajtek1's Avatar
There are 2 ways I use to help in reading the oil on cable.
1. wrap blue masking tape on the end of the cable, but make sure it holds well because if you drop it in the hole you will end up pulling the pan.
2. After pulling the cable out, lay it on the clean piece of paper towel lining the ends. The oily spot will give you measurements.
Kajtek1 is offline
post #7 of 7 (permalink) Old 03-06-2010, 10:36 AM
Date registered: Jan 2004
Quoted: 30 Post(s)
Two things on the 80° temperature deal:
1. I have heard that one exists, but have never actually seen a TSB that indicates that the cold reading on the dipstick should no longer be used. Only use the 80° measurement.
2. I have a digital temp tool, but rarely use it. It is my understanding that when the transmission fluid is hot, that it is 80° so measuring it after a nice drive there is no need to shoot the temperature.
True or false to the above?
Len
'59 220S Cabriolet - for sale - http://www.mbzponton.org/mbz220s/sellswap/car4sale.htm
'83 240D original owner 351,500 miles - for sale - http://www.benzworld.org/forums/w123...g-my-240d.html
'88 560SL 41,000 miles being parted out - https://sites.google.com/site/mercedesstuff/home
'99 E300 turbo 196,000 miles
'03 SLK320 34,500 miles
'14 Smart electric
sokoloff is offline
    Reading Transmission Dipstick Tool 722.6 CrossT W210 E-Class 50 12-16-2014 05:29 AM
    FS: MB Dipstick Tool for 722.6 Transmission cyeung65 For Sale/Wanted/Trade/Giveaway 5 01-17-2011 10:33 AM
    DIY Mercedes 722.3 722.4 722.5 Transmission K1 Piston Spring Repair Kit Install HATTENATOR W201 190-Class 83 10-27-2010 12:19 PM
    MB Transmission 722.6 & 722.9 oil change from MB Service Dawson AMG W210 E50 AMG, E55 AMG 23 11-24-2009 10:52 PM
    FS OEM 722.6 transmission dipstick tool used once ProV1x For Sale/Wanted/Trade/Giveaway 1 06-04-2007 11:24 AM
