R170 ROOF PROBLEM - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 03-05-2010, 03:27 AM Thread Starter
Date registered: Jan 2009
R170 ROOF PROBLEM
Hi All,
I wondered if anyone here knows how to replace the top switch on my R170, I’ve tried searching the forums and can’t seem to find anything despite people giving suggested search strings. Just to give you some back ground the small rear windows would not go back up after the roof locks back into place. I think I know what the problem is as I managed to get them to go back up by grounding pin 30 in the control box whilst putting the roof back up. I found the temp solution in a thread on here. So this leads me to believe it’s the switch above the wind screen. Does anyone know how to get at it to replace it? Anyones help would be very much appreciated and thanks.
Matt
matt1980 is offline
post #2 of 6 (permalink) Old 03-05-2010, 04:26 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 91 Post(s)
Search the R170 forum for postings by "Bazzle". That should narrow things down quite a bit.
Mike
Michael Pillay is online now
post #3 of 6 (permalink) Old 03-05-2010, 07:03 AM
Quoted: 91 Post(s)
This might help. Have you posted your question on the R170 forum?
http://www.benzworld.org/forums/r170...ario-roof.html
Mike
post #4 of 6 (permalink) Old 03-13-2010, 07:49 AM Thread Starter
Right I've had a good read of bazzle's posts I've tried grounding pin 30 in the control box and the windows go back up. Then I tried grounding the circuit at the switches and nothing happens. I've tested the switches and both of them work. Also when I drive the car the roof light flashes and the warning gong sounds. Does anyone have any other ideas your help is much appreciated.
Matt
matt1980 is offline
post #5 of 6 (permalink) Old 03-13-2010, 11:34 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Get the service CD
Star Service CDs and DVDs
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #6 of 6 (permalink) Old 03-13-2010, 11:36 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
Matt,
in the above link scroll down to "Vario roof diagnostics & troubleshooting guide" that should help narrow it down.
also heres a helpful link Top Operation
there's a few more links in my signature.
leapyfish is offline
    R170 Roof problem, trunk doesn`t open BoBKa R170 SLK-Class 5 06-30-2009 04:36 AM
    SLK R170 Headlamp washer problem justin.glover1 R170 SLK-Class 8 05-26-2009 09:14 AM
    R170 top problem dumokie R170 SLK-Class 0 09-25-2008 03:25 PM
    R170 cable loom near roof pump chafing tl99999 R170 SLK-Class 1 12-29-2007 06:33 AM
    r170 '99 Roof Problem, again! CLK320s R170 SLK-Class 1 04-30-2007 07:51 PM
