Alignment yes or no when no wear patterns present - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-04-2010, 02:49 PM Thread Starter
Date registered: Mar 2010
Vehicle: 2007 C230
Post Alignment yes or no when no wear patterns present
I just replaced the back tires on my 07 C230 at 28k. Fronts have about 15K left. Should I have the car aligned? There was and are no wear patterns on the tires. Just end of life for the backs. Car has no other problems. MB Service says yes/once a year or when tires are changed. A friend who is a sales manager for MB says not to worry. Thoughts?
Drewscar is offline
post #2 of 7 (permalink) Old 03-04-2010, 05:06 PM
~BANNED~
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
If you start to see wear patterns or you drive on really bad roads, then get it done. Otherwise you can get a lot more time between alignments. 28k miles on Conti Craptac tires is amazing.
mr.xpowerseller is offline
post #3 of 7 (permalink) Old 03-04-2010, 07:57 PM
Date registered: Feb 2005
Vehicle: 96 SL500, 97 E420,
Quoted: 6 Post(s)
Send a message via Yahoo to gqmagic
Regular alignments will prevent uneven wear patterns in the 1st place.
I get a lifetime alignment policy for every car I buy, then I can go 2-3 times a year if I feel like it.
If you can rotate your tires you should get even wear on all tires, though its harder to do with staggered tires.
gqmagic is offline
post #4 of 7 (permalink) Old 03-05-2010, 09:21 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Wheel alignment is a scam more often than not.
You ONLY EVER need it if
-you've been in an accident
-the car is old and suspension/steering parts are worn
-it was done incorrectly last time
There is NO SUCH THING as an alignment that doesn't involve installing new parts (except obviously for the rather silly reason #3) Bent or worn parts cannot be "adjusted for," only replaced.
So, if it isn't obvious to you that you need an alignment, you don't. (You'll know if you've been in an accident and worn parts will often tell you so via steering feel or tire wear.) Things don't go out of adjustment, move to another place, and then get tight again. When things get loose, they stay loose, and most of the time you can feel it. When things are loose, it's because they're worn out and must be replaced.
Every pothole you hit doesn't bend something--cars are better built than that. A pothole hit bad enough to bend alignment-relevant parts will probably have also destroyed a tire and bent a wheel. That is, it was an "accident!" Tire/wheel problems are more likely in these instances, and don't necessarily mean alignment was affected. Tires/wheels aren't as strong as suspension/steering parts.
Also significant is the fact that zip/zero/nada independent alignment shops carry Mercedes parts, so alignment at a dealer or maybe Mercedes specialty independent shop is the best idea. These parts are NOT generic.
If you feel like paying one of these guys for a "check," go right ahead, but if they haven't replaced parts, you never needed to go there in the first place or they've sent you away with any problem not yet fixed.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #5 of 7 (permalink) Old 03-05-2010, 01:59 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 383 Post(s)
Well said! ^^^^
keyhole is offline
post #6 of 7 (permalink) Old 03-05-2010, 03:08 PM Thread Starter
Vehicle: 2007 C230
aligment thanks
I was able to get it done through the dealer for next to nothing. $45. More piece of mind than anything.
Drewscar is offline
post #7 of 7 (permalink) Old 03-05-2010, 06:34 PM
Quoted: 6 Post(s)
Even wear is a good thing
gqmagic is offline
    bolt patterns ltcbm General Mercedes-Benz 0 05-01-2009 01:59 PM
    The FBI wants your iris patterns, face-shape data, scars & your walk & talk patterns Jakarta Expat Off-Topic 1 12-24-2007 12:06 PM
    "Brake Wear" after suspension/alignment revolt1112 W164 M-Class 3 07-19-2007 10:36 PM
    CLK 55 Front Tire Wear, Alignment & Camber haralds C208/A208 CLK-Class 2 02-23-2007 07:57 PM
    Front end wear / alignment.... supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 10-16-2004 07:59 AM
