drive belts - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-04-2010, 11:57 AM Thread Starter
Date registered: Apr 2009
Vehicle: 1989 420sel & 1993 saab 9000cs
Post drive belts
hi guys, i notice a rip on a small belt bottom left of engine,what is this belt,the car is a 1989 420 sel.thanks
ready6six is offline
post #2 of 4 (permalink) Old 03-05-2010, 11:26 PM
Date registered: Mar 2010
A drive belt is a loop made from any flexible material used for the efficient transmission of power in various industrial applications. Belts are the cheapest utility for power transmission between shafts that may not be axially aligned.
Damiancott is offline
post #3 of 4 (permalink) Old 03-06-2010, 05:57 AM
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 7 Post(s)
^^^ cute! But here is a more inclusive description:
1. a band of flexible material, as leather or cord, for encircling the waist.
2. any encircling or transverse band, strip, or stripe.
3. an elongated region having distinctive properties or characteristics: a belt of cotton plantations.
4. Machinery. an endless flexible band passing about two or more pulleys, used to transmit motion from one pulley to the other or others or to convey materials and objects.
5. Military.
a. a cloth strip with loops or a series of metal links with grips, for holding cartridges fed into an automatic gun.
b. a band of leather or webbing, worn around the waist and used as a support for weapons, ammunition, etc.
6. a series of armor plates forming part of the hull of a warship.
7. a broad, flexible strip of rubber, canvas, wood, etc., moved along the surface of a fresh concrete pavement to put a finish on it after it has been floated.
8. a road, railroad, or the like, encircling an urban center to handle peripheral traffic.
9. Slang. a hard blow or hit.
10. Slang. a shot of liquor, esp. as swallowed in one gulp.
11. Automotive. a strip of material used in a type of motor-vehicle tire (belted tire), where it is placed between the carcass and the tread for reinforcement.
–verb (used with object)
12. to gird or furnish with a belt.
13. to surround or mark as if with a belt or band: Garbage cans were belted with orange paint.
14. to fasten on (a sword, gun, etc.) by means of a belt.
15. to beat with or as if with a belt, strap, etc.
16. Slang. to hit very hard, far, etc.: You were lucky he didn't belt you in the mouth when you said that. He belted a triple to right field.
17. Informal. to sing (a song) loudly and energetically (sometimes fol. by out): She can belt out a number with the best of them.
18. Slang. to drink (a shot of liquor) quickly, esp. in one gulp (sometimes fol. by down): He belted a few and went back out into the cold.
19. below the belt, not in accord with the principles of fairness, decency, or good sportsmanship: criticism that hit below the belt.
20. tighten one's belt,
a. to undergo hardship patiently.
b. to curtail one's expenditures; be more frugal: They were urged to tighten their belts for the war effort.
21. under one's belt, Informal.
a. in one's stomach, as food or drink: With a few Scotches under his belt, he's everyone's friend.
b. considered as a matter of successful past experience: I don't think our lawyer has enough similar cases under his belt.
OK, but back to the intent of the OP's post:
Bottom left - probably air pump. If one is bad, they probably all are. Do not buy cheap autozone belts either. Buy premium belts.
But it really sounds like you should pay somebody to do this job if you can't determine what the belt is driving. Make the belts too tight, and bearings on the driven accessories will start failing (expensive). Too loose and they will slip or pop off (could be expensive).
You can find a local independent mechanic I am sure.
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
post #4 of 4 (permalink) Old 03-06-2010, 08:10 AM
Kajtek1's Avatar
Quoted: 1070 Post(s)
I don't think the OP come here for English lesson, but he got it anyway.
"rip" on the belt is not giving really good description. I had rip on my tractor belt and drove it like that for 6 years and finally replaced the belt only because was annoyed with the spare taking storage space.
This way, or the other it is good idea to carry spare belt and tools to replace it.
Kajtek1 is online now
    Supercharger Belt and Drive belts where to buy ? Mark600RRBryant R170 SLK-Class 5 09-17-2005 07:42 AM
    Is it hard to install drive belts S/c belts? Mark600RRBryant R170 SLK-Class 1 09-12-2005 03:26 PM
    Drive Belts Quiz janos_z W126 S,SE,SEC,SEL,SD,SDL Class 8 02-20-2004 09:02 PM
    lots of new ML owners, Let's discuss all-wheel drive, 4wheel drive and full time 4wheel drive.... guy W163 M-Class 10 12-09-2001 06:08 AM
    Anyone know where I can get colored seat belts? Like the custom porsche belts? Long R170 SLK-Class 1 04-29-2001 03:24 PM
