E320 1995 engines shakes, DTC code 10 flashes - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-01-2010, 09:00 PM Thread Starter
Date registered: Mar 2009
Unhappy E320 1995 engines shakes, DTC code 10 flashes
I have a E320 1994. Engines shakes hard when start and driving. I replaced new spark splug. problem did not go awa so I took to the shop and they tell me coil is ok, compressor is ok. They think it is electronic problem an dit cost $600-700. My car may cost about the same!
I push th selftest button. only LED position #4 flashes 10 times.
Could someone to advise what is the actual problem?
and what need to raplace and cost?
Thanks in advanced.
Duke
dukeoftest is offline
post #2 of 10 (permalink) Old 03-02-2010, 08:48 AM
Date registered: Jul 2004
Quoted: 316 Post(s)
"only LED position #4 flashes 10 times" doesn't really make sense. Can you clarify?
deanyel is online now
post #3 of 10 (permalink) Old 03-03-2010, 10:51 AM Thread Starter
First there is a typo . My car is 1994 E320.
I checked there is only one LED for selftest.
Push the button , the LED flahes 10 times.
Thanks
Duke
post #4 of 10 (permalink) Old 03-03-2010, 04:46 PM
Quoted: 316 Post(s)
The built in pushbutton and LED is pin 3, diagnostic module, aka the DM. Code 10 is telling you to read the fault codes on the HFM which is pin 8. In order to read the codes on pin 8 you need to build the homemade flash code reader with parts from Radio Shack - lots of info in the archives.
post #5 of 10 (permalink) Old 03-08-2010, 03:29 PM Thread Starter
I have 2 questions:
1) i push slftest button , it gives 10 flash and I look at Dm table. code 10 indicate AMF problem. Where do i find the instruction that say to read fault code on HFM?
2) I build a flash read code. But not sure what LED to use. It must be high current.
Do you know the part number for LED? Does it has limiting current resistor built in?
Thanks for your help
post #6 of 10 (permalink) Old 03-08-2010, 06:06 PM
Quoted: 316 Post(s)
STAR TekInfo
The LED is Radio Shack part number 276-270 - http://www.radioshack.com/product/in...ductId=2062568
post #7 of 10 (permalink) Old 03-09-2010, 10:31 AM Thread Starter
Deanyel,
The DTC table i got from other website does not have the second column.
Thanks.
Duke
post #8 of 10 (permalink) Old 05-08-2010, 07:24 PM
Date registered: May 2010
Vehicle: 1995 E320 (CA spec)
Any resolution to this issue?
I'm having the same problem; Code 10 on the DM and engine shuddering. I cannot get the codes off the DM, built two radio shack readers, none will work.
sea320 is offline
post #9 of 10 (permalink) Old 05-08-2010, 09:33 PM
Date registered: Jun 2009
Vehicle: 1991 300E
This previous post consolidates links to resources for code listings, schematics and accumulated wisdom, much of it from discussions on the Peach Parts forum.
300E91 is offline
post #10 of 10 (permalink) Old 05-10-2010, 02:15 PM Thread Starter
engine shake problem
I could not get my reader read any code. But I found the problem due to the wire connecting spark plugs is bad. Assumming that the coil are good, after replacing spark plugs, check your core. You can use the ohmeter to beep it out for continuity. BUt i suggest to replace if they are old.
    DTC code 17 on DI module ? Brian McL R129 SL-Class 4 12-03-2009 07:17 PM
    Audio Code needed for 1995 Mercedes E320 sonu_tc General Mercedes-Benz 0 11-02-2008 11:32 AM
    check engine light... code 3 (3 flashes) LeftCoastBias W201 190-Class 4 08-06-2007 03:23 PM
    P0170 DTC code ALephart R170 SLK-Class 4 04-07-2007 04:24 AM
    P0400 DTC code Jagermeister W210 E-Class 0 05-18-2006 06:05 PM
