Electronic Throttle Control - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-24-2010, 08:02 PM Thread Starter
Date registered: Feb 2006
Vehicle: 2013 ML350, 2013 Ram 1500, 2011 Ferrari 599
I've been told that Mercedes-Benz vehicle's throttles will return to idle when the brake is depressed, thus avoiding the unintended acceleration problem currently experienced by Toyota/Lexus. Does anyone know if this is true?
Barry Hanna is offline
post #2 of 3 (permalink) Old 02-24-2010, 08:25 PM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
Yupp... Pretty annoying. No burnouts.
Kajtek1 is offline
post #3 of 3 (permalink) Old 02-24-2010, 08:45 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 348 Post(s)
On my 97 E-420 with electronic throttle, Partially true: Later vehicles may be entirely different
If your stopped NO!. Nice for burnouts.
If your moving, sort of, but it takes a few seconds for anything to happen, and then you get reduced power, but not down to "idle levels"
Did an experiment with my 420 and my duramax silverado (with a +90RWHP tune- 300RWHP, 600lb/ft RWtorque)
On both vehicles I was able to easily brake hard enough under full throttle second gear to invoke ABS. On both vehicles the engine management would kick in after a few seconds of braking and reduce power, but not down to idle.
Although I also believe that on both vehicles if you "pussy footed" the brakes at high speed you would end up overheating the brakes before you came to a stop. You would need to brake reasonably agressively to stop the vehicle.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
    Electronic Throttle Control Module needed urgently El Prez W140 S-Class 14 08-28-2012 09:57 AM
    Electronic throttle control vs mechanical linkage, which models use what? DubVBenz General Mercedes-Benz 6 02-07-2010 11:46 AM
    Electronic throttle actuators majorcynik R129 SL-Class 5 08-27-2009 12:56 AM
    Electronic Throttle Actuator 92 500SEL rightstuff4u W140 S-Class 3 08-12-2009 10:29 PM
    Can I convert wired throttle to electronic throttle? eddietham R170 SLK-Class 12 03-25-2007 12:45 PM
