Diagnostic help! 1994 C220 - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-24-2010, 01:50 PM Thread Starter
Date registered: Feb 2010
Hey there,
Need some expertice please. I have resusitated a 1994 C220 (Canadian version), can starts and idles fine, even runs well for say 10mins, but once warm the engine bogs down, it's difficult to accelerate, and causes hard auto tranny shifts. I need some help determining what the issue could be.
I'm thinking the coils, wires or plugs, bad cat converter...any or all of these? Please help.
Thanks, Rampton
Rampton is offline
post #2 of 5 (permalink) Old 03-01-2010, 07:00 PM Thread Starter
Come on please someone must have some ideas?
Bump
Rampton is offline
post #3 of 5 (permalink) Old 03-01-2010, 07:11 PM
Date registered: Sep 2006
RE:Diagnostic help! 1994 C220
Mass Air Flow sensor. Try cleaning it first, they make aerosol spray just for MAF sensors. Don't use regular carb cleaner or brake cleaner. This may help, if not you need a new sensor. Remember this is just a stab in the dark, to know for sure you need to get a scan tool, like SDS on it to see what the fuel adaptation is at. But the MAF is a common failure item and will cause the symptom you describe. If you can get someone to put a diagnostic tool on the car and you can look at the mixture adaptation, it should be right at 1.00 or close to it....if it is less than 1.00 then the car is running rich, if it is more, then it is lean. The MAF will make it run lean, especially in the partial load range, because it is telling the computer that there is less air coming in than there actually is, so the computer cuts back on the fuel injection quantity. Good luck.
Chris
ctmaz68 is offline
post #4 of 5 (permalink) Old 03-02-2010, 07:24 AM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
You own a first gen W202 chassis. There is a forum on this site for that chassis. It might help if you ask your question on that forum because there is a room full of people who own the same (or some variant) car you do. The likelihood of them having a more experienced diagnosis is higher than this general forum.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #5 of 5 (permalink) Old 03-02-2010, 01:57 PM Thread Starter
Duly noted and completed...thanks...
Rampton is offline
    1994 C220 Will Not Idle stevepinkerton W202 C-Class 2 12-26-2008 02:34 PM
    1994 E320 Diagnostic codes dshaver2000 W124 E,CE,D,TD Class 3 07-15-2008 03:50 PM
    1994 C220? jmas2k W202 C-Class 1 06-15-2006 05:44 AM
    Need help in my 1994 C220 sport melbs W202 C-Class 0 08-30-2004 09:16 AM
    1994 c220 ... almost start. J Man W202 C-Class 2 01-27-2004 12:19 PM
