Intermittent electrical Fault - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-24-2010, 03:10 AM Thread Starter
Date registered: Feb 2010
Thumbs down Intermittent electrical Fault
Hi eveyone I'm new to the forum and have a 1999 Mercedes Vito 108 with a tow bar , I have an Intermittent electrical Problem Causing the engine to cut out,(can go 1 or 2 days without a hitch then all hell will break loose for a period leaving the van for a day seems to give another couple of days without to much trouble) this fault can be caused by one or all of the following,
1 engaging Reverse Gear
2 applying foot break
3 indicating
Things Tried so far
1 All earths to the rear light clusters removed cleaned and replaced
2 All earths in the engine compartment removed and cleaned
3 Electrics to tow bar removed (problem still apparent so electric’s replaced)
4 Jacked the Van up and looked for any Broken Chafed or loose connectors
5 Connections behind the radio and gearshift inspected
One point. The near rear side stop light has always blown on a regular basis since the van was purchased in 2001
hillsbarn@btopenworld.com is offline
post #2 of 2 (permalink) Old 02-24-2010, 05:35 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
Gearbox intermittent fault? fredyflame R170 SLK-Class 4 06-21-2009 02:00 PM
Intermittent Fault Stevie H R170 SLK-Class 4 06-12-2008 02:11 PM
Intermittent fault with windscreen wipers jasper-1912 W202 C-Class 3 04-06-2005 07:20 PM
Speedo and tacho intermittent fault wmedia W140 S-Class 3 01-11-2005 08:37 AM
SRS intermittent fault Guest (MBNZ) W140 S-Class 1 10-21-2001 07:16 AM
