Replacing injectors in Sprinter 313CDI - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-23-2010, 10:42 AM Thread Starter
Date registered: Feb 2010
Hi
Just about to replace injectors after a good clean up of the Black Death!! Once I have got the injectors back in, new copper washers and new stretch bolts etc etc, can I just reconnect the bleed off pipes to the top of the 4 injectors, or do I need to bleed or prime something befor I crank things over?
This is a whole new ball game!! Thanks in advance
rykalov is offline
post #2 of 4 (permalink) Old 02-23-2010, 11:26 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
No need for priming really. Did you check that the copper washers sit on an even face so that they don't start leaking again?
Diesel Benz is offline
post #3 of 4 (permalink) Old 02-23-2010, 11:41 AM Thread Starter
Hi thanks for your response. Yes I have cleaned the bottom faces. firstly, plugged the holes to keep the crap out the used a gun barrel wire cleaner(gently), covered over every other hole nearby and blasted with a fine air hose nozzel!, although getting to have a look down the last injector was a pig. I just hope the blow by has not etched a groove in the head!!It had been going on for a while, but not like some of the horror stories on here!
I was thinking of leaving the plastic cover off for a while just to keep an eye on things. I have not been having any power problems or starting issues, it was spotted when doing a service. so hopefully it was just the washer being U/S.
Thanks
rykalov is offline
post #4 of 4 (permalink) Old 02-23-2010, 11:51 AM Thread Starter
Just wanted to add to my last post. I had to buy a new bleed off pipe to the 4 injectors (new metal connectors now). One of the plastic T pieces broke. Absolutely fleeced by Mecedes to tune of £74 + vat !!! All that 12 inches of pipe and 4 small connectors. any ideas where I can get a better deal for bits in the future.
thanks
rykalov is offline
    just bought a 313cdi sprinter need help xfiles W901-905 Sprinter 5 09-22-2009 10:12 AM
    mercedes sprinter 313cdi non start MF494 W901-905 Sprinter 3 02-28-2009 03:14 AM
    sprinter 313cdi wont get hot cabin louist W901-905 Sprinter 0 01-28-2009 08:55 AM
    which oil sprinter 313cdi manual xfiles W901-905 Sprinter 7 04-22-2008 02:06 AM
    For sale sprinter 313cdi stirzo For Sale/Wanted/Trade/Giveaway 0 05-04-2007 02:49 PM
