Mercedes C220 diesel - horn & auto lights not working? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-20-2010, 03:12 PM Thread Starter
Date registered: Feb 2009
Hi, I was wondering if anyone can help me troubleshoot a problem with my 2003 UK spec right hand drive c-class c220 diesel?
All of a sudden, the horn has stopped working and so has the auto setting on the lights? The car is fitted with xeon headlights but only the drivers side headlight will switch on? I understand this is a common fault that needs an expensive replacement unit to fix it?
If I switch the main lights off and on a few times without the engine running, they eventually both switch on.
Could this be related to the horn problem as well?
I have no manual with the vehicle so can't tell where there might be a fuse problem 'if' there is even such a thing? How do I even consider troubleshooting this?
Has anyone got any idea where such a fuse for the horn might be? I can see the fuse box under the hood next to brake servo but I have no diagram of which fuse does what and they are not numbered
Can anyone help please?
Thanks in advance!
Dave.
Decay is offline
post #2 of 3 (permalink) Old 02-20-2010, 07:25 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You have what Mercedes calls a W203 so I would post on that forum. You'll find it under the sedans section. Even if you had a fuse chart MB calls the horn fuse something other than horn but I can't remember what. You need to find an owner's manual and fuse charts.
Musikmann is offline
post #3 of 3 (permalink) Old 02-21-2010, 12:02 PM Thread Starter
thanks, I didn't realise it was classed differently by MB, i'll try posting there!
Decay is offline
1998 C220 Diesel Elegance Stalling and Auto gearbox lumpy Herrling W202 C36 AMG, C43 AMG 2 03-11-2009 02:55 AM
Yes I did do a search. No working horn, seatbelt buzzer and reverse lights. mybenz123 W123 E,CE,D,CD,TD,TE Class 4 11-09-2008 09:31 PM
Auto Up & Down in Windows stopped working?? lowneygo W202 C-Class 3 11-09-2008 03:27 PM
Horn stop working, where is the fuse for the horn njstreeter W203 C-Class 1 09-09-2008 09:53 AM
C220 CDI Warning lights & vibrations when braking fififolle W203 C-Class 3 02-15-2008 07:03 AM
