Mercedes Surge Performance Chip - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-19-2010, 02:33 PM Thread Starter
Date registered: Feb 2010
Does this chip really work and will it affect my warranty?
Here is the link to the site:
Mercedes Surge Performance Chip by Surge Engineering Performance Parts
miracleMaxx is offline
post #2 of 4 (permalink) Old 02-19-2010, 06:47 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 354 Post(s)
question 1: don't personally have a clue
question 2: depends on which country you live in and how "friendly" your dealer is. In the U.S. there are those who will claim that Magnesun Morrison warranty act forces the mfg to prove the aftermarket device caused a failure. However, what most don't realize that MM only applies to aftermarket parts used in mfg defined normal service for warranty (e.g. filters, oil, other fluids). By the way thanks to MM you are not required to go to the mfg (dealer) for routine service to maintain the warranty. If the mfg requires you to use there service only, they must provide the service for free.
Mfg have the legal right to deny warranty claims for failures related to performance enhancing devices. (e.g.engine & transmission failures) It's a big issue on ford, GM, Dodge diesels since it is easy to add 150+ RWHP to there diesel trucks. As you might expect, that puts a good strain on lots of drivetrain parts, and an invitation for failures.
With gas engines, there doesn't appear to be near as much an issue, since your seldom going to get more than maybe a 10% increase in power, if that. Probably not enought to raise a reliability issue. By contrast, with turbo diesels a 50% increase in RWHP is pretty easy to do, at least on the big 3 diesel trucks.
So it really depends on how the dealer acts and how aggressive the mfg is. Some will fix stuff under warranty, others will not.
GM is now at the point on duramax diesels that they can determine if any of the last 10 ECM programs were non factory programs and if any were, drivetrain warranty is voided.
I'm sure some may disagree with my statement about MM applicability to "powerup devices" , but I don't think fighting a mfg is an easy task.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #3 of 4 (permalink) Old 02-20-2010, 06:26 AM
StarPower's Avatar
Date registered: Oct 2009
Vehicle: 2003 Lincoln LS V8
The SURGE Performance module simply wires into the factory harness of the IAT sensor.
Translation: IAT = Intake Air Temperature
This chip makes your car's computer think the engine is getting colder air than it actually is. Since it thinks it's getting colder air it thinks it can add more timing without risk of detonation. Most cars (I don't know about MB specifically) are not tuned from the factory to add timing based solely off of colder IAT. Even if MB does, trying to fool the computer is not the proper way to add power. Hopefully, the car's knock sensors will detect any detonation and retard timing (countering the effects of the chip) before any damage is done.
If you want a tune, get one from a reputable vendor. A real ECU tune rewrites the programming in your ECU (engine control unit) to add power. The added cost is well worth the peace of mind of knowing in will work without damaging your engine.
StarPower is offline
post #4 of 4 (permalink) Old 02-22-2010, 09:00 AM
EvoGuy's Avatar
Date registered: Dec 2006
Vehicle: 2004 E500 Wagon, 2004 E55 AMG
I would not use it!
EvoGuy is offline
    PERFORMANCE CHIP MERCEDES BENZ 190E 2.6 1990-1993 MtL-BenzZ W201 190-Class 10 01-12-2014 11:53 AM
    Mercedes Surge Performance Chip BigR W140 S-Class 1 04-21-2009 01:12 PM
    Performance Chip Saff W221 S-Class 0 04-18-2008 08:12 PM
    Surge Performance Chip? r34p3rex W163 M-Class 5 02-27-2008 04:27 AM
    performance chip? dpol1835 R129 SL-Class 0 11-05-2005 06:08 PM
