C280 woes - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-18-2010, 06:17 PM Thread Starter
Date registered: Feb 2010
C280 woes
My 96 c280 just started missing, I think it's cylinder #1. The check engine light is not illuminated though.
I started by taking out the intake pipe, and coil cover off to inspect. I found that the coil-pack closest to the firewall has lime build up along with the plug wire. I cleaned them both up and reinstalled everything. After I put everything back together, the strangest thing happened. My transmission will not shift on its own, I have to shift it manually.(by releasing the accelerator)
The car is still missing, I'm going to pick up a new coil tomorrow.
Anyone ever had this issue before? (the transmission issue)
I did manage to break one of the vacuum lines while moving them out of the way, but I replaced the damaged lines.
Where should I start to fix the shifting issue?
Thanks!
Kabanimotorsports.com is offline
post #2 of 3 (permalink) Old 02-18-2010, 06:35 PM
DirectLA's Avatar
Date registered: Jan 2007
Quoted: 8 Post(s)
To me it does sound like a vacuum line issue, did you use the same type of line to replace it? Maybe one came off if not fitted perfectly. Anyways, for more accurate help come on over to the W202 section where others with your car can better assist you.
W202 C-Class - Benzworld.org - Mercedes-Benz Discussion Forum
-Marrs
The Coupe Group on Facebook
DirectLA is offline
post #3 of 3 (permalink) Old 02-18-2010, 07:09 PM Thread Starter
No, it was a different type of line. I just used some line I had laying around. It was the same size and was a tight fit.
    No A/C woes.. Griff230 R170 SLK-Class 6 07-30-2009 03:04 PM
    More woes... Check Codes W210 E-Class 7 06-19-2007 07:06 PM
    Difference in feel between the 1997 C280 and 1999 C280 SechsPackSound W202 C-Class 3 04-18-2006 05:48 PM
    woes of a brand new c280 4matic...doa johnrmcc W203 C-Class 2 11-15-2005 03:26 PM
    **C280 Experts: Opinions on this C280?? schranz W202 C-Class 0 05-31-2004 03:15 PM
