Transmission repair for 140 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-17-2010, 12:52 AM Thread Starter
Date registered: Jan 2009
Vehicle: 93 500 SEL,89 300E, 91 320 SEL
Thumbs up Transmission repair for 140
Hello to all, I am trying to get a fix on a transmission issue I am having on my 93 500SEL.The trans is a 722.3 4 speed with the B setting at the shifter. The trans. will not engage in any gear. It came about after a normal shift into reverse and then stopped operation. There had not been any indications of any problems and I have kept up maintenence diligently. I have checked the fluid lines to see if fluid was moving. It appears to be flowing, though I have not done a pressure check. I dropped the pan and the fluid was clear, no smell. There was a little sediment but minimul, no particle or chunks, in the pan. The one thing it did do was when I try to shift into a gear and then back into park I hear a clicking sound that stops after 15 to 20 seconds. It sounds like something simple has occured. ALLDATA info indicates the teflon seal needing replaced at B2. Could it be in the valve body? any ideas of what it may be? ANy thoughts would be most appreciatted. I will take a pressure check on the pump and get it posted back to all. thanks in advance. Cheers, Paul
HEESPAUL is offline
    W-140 Transmission Leaking problems? dadefire W140 S-Class 13 02-26-2014 02:21 PM
    Technical Data (W140) S 600 (140.056, 140.057) MBs600v121998 W140 S-Class 4 08-25-2009 07:32 AM
    Transmission Repair blueribbonman W211 E-Class 0 04-26-2009 07:57 PM
    Engine and Transmission Swap 600S (140) to a 560SEL(126) JRB W126 S,SE,SEC,SEL,SD,SDL Class 7 04-20-2006 02:58 PM
    Model 140 Repair Manual on DVD STARTEKINFO_GURU W140 S-Class 2 02-02-2005 08:20 AM
