e320 2004 xeon bulbs headlight leveling/cornering failure - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2010, 01:56 PM Thread Starter
Date registered: Dec 2009
I wonder if anyone can help, I have an E320cdi 2004 and the dash reports a cornering headlamp failure. My driverside headlamp points down and to the right. My near side headlamp goes up and down on startup but no longer left to right but does appear to point correctly ahead.
Does the problem sound like sensors? if so which ones and where are they located.
can I put a voltage accross the headlamp motors to test if light assembly is OK, if so which conector pins to use, I have 2 sets the top one with four wires and the bottom with 3
Any other ideas would be greatly appreciated.
cpholt is offline
post #2 of 4 (permalink) Old 02-16-2010, 10:44 PM
Diesel Benz's Avatar
Quoted: 32 Post(s)
I'm afraid the cornering lamp issue is about internal wring failure at the headlight unit. This is typical for early cornering lights on a W211. The levelling issue sounds like the levelling motor is stuck to the low position. This is probably mechanical, the levelling motor has no sensors but calibrates itself by driving the lights fully down and then running the stepper motor a programmed number of steps up (taking into account suspension level sensors for appropriate tuning).
I don't think you can easily run the motors from an external DC source.
Diesel Benz is offline
post #3 of 4 (permalink) Old 02-17-2010, 01:33 PM Thread Starter
thats a great help thankyou, I will now google how to remove the front light and see if there is anything i can repair inside the unit, if i cannot effect repair then i have nothing to loose and will replace the unit, any ideas where is a good place to purchase drivers headlamp unit part number 2118202261 i prefer 2nd hand due to value of the car.
cpholt is offline
post #4 of 4 (permalink) Old 07-26-2010, 07:01 PM
Date registered: Sep 2008
Vehicle: 04 sl600 w/renn tech dynoed 645HP
Post same on our 2005
did you ever find a inexpensive alternate??
My 05 fails when its under 70 degrees. above and the stupid thing works fine.
had a shop look at it and said 1500 to replace. too much!
thinking of maybe replacing with the non-motion units, any ideals??
sl600_pilot is offline
    08 e320 bluetech headlight bulbs help? pls jimmy5110vo W211 E-Class 13 10-01-2008 03:27 PM
    2004 E320 without Bi-Xenon. Would like to upgrade stock bulbs? Ghetto2315 W211 E-Class 1 04-27-2004 01:33 PM
    help on installing xeon headlights on non xeon model s ///amg W220 S-Class 1 06-05-2003 06:32 AM
    Replacement headlight bulbs for 95 E320 semandell W124 E,CE,D,TD Class 2 08-23-2002 03:46 PM
    OT. Check out MBSPY's article on MB's new Active Cornering Headlight System.... Butch R170 SLK-Class 0 07-25-2002 12:52 PM
