94 E320 ignition switch removal - need help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-15-2010, 02:59 PM Thread Starter
Date registered: Dec 2009
Vehicle: 94 E320 SEDAN
I've removed the lower dash and have the ignition switch exposed. To remove it, it looks like you twist and pull the whole switch and cylinder but right close to the steering column it looks like there is a pin that has to be removed. Can anyone tell me how to remove the pin so the entire ignition switch will remove? I thought it might be a spring loaded pin that you push on but it won't push in at all. The only other option I see is to drill the pin out so you can remove the entire switch. Without pulling the entire thing out I don't see how you could possibly get at the screws that hold just the switch half of the switch and cylinder together. Can anyone please help?
psalyer is offline
post #2 of 2 (permalink) Old 02-15-2010, 03:08 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Try doing a search or asking on the W124 forum, that's the car you have.
Musikmann is offline
    96 w202 ignition switch removal beezeenz W202 C-Class 9 07-26-2011 11:35 AM
    Is this the right sequence for ignition switch removal? guarddog W126 S,SE,SEC,SEL,SD,SDL Class 15 09-11-2009 07:11 PM
    '85 300SD Ignition/start switch removal. jbleaux W126 S,SE,SEC,SEL,SD,SDL Class 2 11-19-2005 06:09 PM
    71 250 Ignition switch removal Nutz 4 Benz Vintage Mercedes-Benz 1 10-08-2005 11:02 AM
    Ignition switch removal BR-549 Vintage Mercedes-Benz 0 09-26-2005 08:24 AM
