Coolant - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-15-2010, 08:47 AM Thread Starter
Date registered: Feb 2010
What I cannot used regular coolant and need to use MB coolant? Will regular coolant damage the system?
montaed1 is offline
post #2 of 6 (permalink) Old 02-15-2010, 09:58 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Uh huh.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 6 (permalink) Old 02-15-2010, 10:58 PM
Kajtek1's Avatar
Quoted: 1057 Post(s)
Try it and let us know?
Kajtek1 is online now
post #4 of 6 (permalink) Old 02-16-2010, 04:25 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Go 'head. Let us know how it works for you.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #5 of 6 (permalink) Old 02-16-2010, 04:57 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
y dont u give it a shots n let used no
mr.xpowerseller is offline
post #6 of 6 (permalink) Old 02-16-2010, 06:51 PM
Date registered: Aug 2008
Vehicle: 2008 E320 Bluetec, 1988 560SL totalled unto death). 1997 Dodge Ram 1500, 1983 300CD
Quoted: 152 Post(s)
MB coolant
Conventional wisdom says to stick with the MB coolant or the ZEREX equivalent. That is what I use in my Benz and so do most others on this forum.
That said, a "conventional" coolant such as PRESTONE that is designed for aluminum engines would probably cause no damage. Almost all automotive radiators today also use plastic components, one of the reasons given for using only MB coolant. I use PRESTONE in my Dodge truck with it's plastic radiator tanks. Now has 136000 miles with no cooling system problems.
BUT ... the difference in cost is small and the peace of mind is large so my advice is to use the right stuff if you can. Are you located where access to MB or ZEREX is difficult?
By the way, don't let the discourteous replies you receive from some discourage you from posting questions.
rocky raccoon is offline
    MB Original Coolant (Yellow) & Green Coolant dwijesh sheth W202 C-Class 38 01-30-2011 01:22 PM
    low coolant light intermittent & dim but good coolant level idkmybffcms W124 E,CE,D,TD Class 4 03-14-2009 12:47 PM
    anyone tried Prestone/other 5 yr Coolant (instead of the Benz Coolant) heartmd W140 S-Class 6 11-17-2007 09:28 AM
    Time for coolant change - which coolant? oberoi R170 SLK-Class 10 11-13-2006 02:51 PM
    What does a coolant leak smell like with MB coolant? pcmaher W140 S-Class 3 09-27-2004 11:47 AM
