ML 320 2000 starting problems - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-13-2010, 07:45 PM Thread Starter
Date registered: Nov 2009
Hi i have a ML 320 2000 and today when i driving to my home in the midle of road it turn off and i have to park inmediatly. when i tried to star it cranks but not start so i call a tow truck to take me home. Maybe a month ago it did a similar problem i drive for a while ann then when i park a left abot 1 or 2 hours it cranks but not start then i check the fuel pressure and no have any pressure. I change the fuel pump and also the spark plug and it runs very fine for 3 weeks until now. Another problem when i drive suddenly it apply the break with no reason and turn on the BAS ESP Light also i change the brake light switch but does the same problem again. Someone that help me please. Thank You
mecdiesel is offline
post #2 of 5 (permalink) Old 02-14-2010, 05:31 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Any fault codes? Especially relating to the crankshaft position sensor, for example?
flyboyike is offline
post #3 of 5 (permalink) Old 02-14-2010, 11:55 AM Thread Starter
no i check with a scanner and no codes retrieve iam frustate because it have fuel pressure but i dont know what it is how i know if the CPS are bad???
post #4 of 5 (permalink) Old 02-14-2010, 06:51 PM Thread Starter
Please someone help me
post #5 of 5 (permalink) Old 02-14-2010, 09:28 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Since you changed the fuel pump (a known weakness in the chassis) with those symptoms I'd go with the crank position sensor. Inexpensive part and easy enough to DIY, it typically does not throw codes when it fails.
FWIW, you're much more likely to get specific help if ypu post in the W163 forum, which focuses on your chassis.
Good luck, see you in the 163 forum.
Check Codes is offline
    ML 320 2000 brake problems mecdiesel W163 M-Class 1 02-05-2010 04:57 PM
    ML 320 fuel problems and starting mecdiesel W163 M-Class 2 01-18-2010 07:18 AM
    2000 ML 320 Problems kboogie668 W163 M-Class 12 08-17-2008 09:36 AM
    2000 ML 320 problems Simon W163 M-Class 8 05-06-2002 02:21 PM
    2000 SLK 320 auto-transmission problems and more heather R170 SLK-Class 5 10-20-2001 01:57 PM
