Heater Won't Switch from Defrost to Floor - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-13-2010, 01:03 PM Thread Starter
Date registered: Feb 2010
Vehicle: 82 Mercedes 300-TDT
I have an 85 300DT and while the defroster on the car works fine (I just changed the blower/motor), I have never been able to use the console switches to change from defrost setting to the floor. Regardless of the switch I choose, it remains fixedly on defrost setting.
Is there an easy fix for this so we don't have to drive with frozen toes?
danashields is offline
post #2 of 6 (permalink) Old 02-13-2010, 02:27 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Sounds like your vacuum controls are not operating and the system defaults to defrost.
The vacuum connectors in the oil filter area are the most common problem.
Kajtek1 is online now
post #3 of 6 (permalink) Old 02-13-2010, 03:15 PM Thread Starter
Heater Stuck on Defrost
I take it that since I combed through the vacuum lines around the filter and that they all look good, the same could hold true for any lines that go through the firewall, correct?
If so, I'll remove the under dash panel tomorrow to give it a look-see.
post #4 of 6 (permalink) Old 02-13-2010, 04:20 PM
Kajtek1's Avatar
Go to W123 section for more info how to deal with those pesky vacuum lines.
At some age they cost lot of troubles. Is you engine shutting off OK?
I wouldn't rush into opening the dashboard before double checking the easy stuff.
post #5 of 6 (permalink) Old 02-14-2010, 06:05 AM Thread Starter
Vacuum Lines
Engine shuts off fine. But vacuum lines don't work for door locks either. I was under the panel a couple of years ago to install something, so it's possible that it was I who was the bonehead who jarred something loose under the dash.
I will take some time to look under the W123 topic. I didn't see a page devoted to W123 on the forum's main menu, but I'll keep hunting around. (Hopefully I won't jar anything loose in my quest to find it.)
post #6 of 6 (permalink) Old 02-14-2010, 10:41 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Look in the sedans section for W123. If your locks aren't working that might point to the PSE pump. Locate that and check the tubes coming from it.
Musikmann is offline
    Very weak defrost and floor heat! ksing44 W124 E,CE,D,TD Class 15 12-14-2008 01:33 PM
    Defrost & Heater: Any Problems? LGV W221 S-Class 4 11-11-2008 06:15 PM
    ashtray and defrost switch mercbuff W140 S-Class 0 07-16-2005 07:40 AM
    2001 C240 HEATER FLOOR HEAT MAX BLAKELY W203 C-Class 0 02-20-2004 06:29 PM
    Climate Control Switches from Floor to Defrost E320Wagon General Mercedes-Benz 1 02-20-2004 01:26 PM
