ml 270d not firing in cold weather - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 02-12-2010, 12:36 PM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
Isn't your jet diesel-powered?
Kajtek1 is online now
post #12 of 15 (permalink) Old 02-12-2010, 12:55 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Good point. It's actually kerosene-powered, but it will run on diesel. EPA might take objection to that. There are actual diesel engines in aviation (Thielert et al), but they run on kerosene (jet fuel).
flyboyike is offline
post #13 of 15 (permalink) Old 02-12-2010, 01:22 PM
Kajtek1's Avatar
Jet fuel is more known as a modified diesel fuel, than modified kerosene.
There are all products coming from the same oil, so the lines where one product starts and the other end can be pretty murky.
Still the point, that diesel, or kerosene have to be modified to withstand low temperatures and still keep minimum lubrication is valid.
When you use summer blend in cold winter -you are going to have troubles.
post #14 of 15 (permalink) Old 02-12-2010, 02:28 PM
Date registered: Feb 2007
Vehicle: 2004 C270cdi Avantgarde SE-A and 2006 ML320 CDI Sport
Just had same problem sorted on my c270cdi 04 plate
Was not glow plugs or injector seals, took it to specialist who have done loads of the same problem over this winter. There are 3 pipes from the fuel pump that needed to be replaced, they were leaking slightly at the seals of the pipes and these seals are part of the pipes, hence you have to buy complete pipes. Cost me £208 to have done, including £60 on Star diagnostics... i was starting my on easy start too!
iimms is offline
post #15 of 15 (permalink) Old 02-12-2010, 07:47 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 349 Post(s)
Originally Posted by flyboyike View Post
You mean diesels have a hard time starting up in cold weather? Who woulda thunk it?
Not me, I've started mine (6.6l duramax Silverado) at -40F (-40C) even without plugging it in. Stinks for a while, and rattles prett good, but starts fine as long as it's on winter fuel.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is online now
    Mis-Firing E240 when cold @itude W210 E-Class 0 02-02-2010 08:33 AM
    Cold Weather?? Ihitacurb W203 C-Class 3 12-14-2008 06:15 PM
    Shuddering while Engine Cold/Cold Weather bondavi W126 S,SE,SEC,SEL,SD,SDL Class 1 03-29-2008 08:08 AM
    Cold Weather 430 R170 SLK-Class 3 02-14-2006 12:10 PM
    First flash of sub-'0 weather here - and first "cold weather" accidents Max R170 SLK-Class 1 12-11-2002 05:31 AM
