EZL-KAT timing 190E -92 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 02-10-2010, 02:49 PM Thread Starter
Date registered: Feb 2010
First i repaired the OVP relay and got the idle ok. Thanks to you here I had good help diagnosing and treating the OVP relay.
Than I just found another EZL-KAT timing device - it is behind the battery and sealed. The one in front has been turned - because the manual says it should be on S but is now standing on 1. And the one behind the battery also stands on 1. Both have seven possible positions.
So my question is shall I turn the EZL-KAT in front to S?
And what other adjustments are there for ignition and fuel? So far I have found the two EZL-KAT-devices and a hole in the air cleaner for adjusting CO on the fuel distributor. Are there any more?
The car is a 190E 1.8 Liter 1992 (With catalyst).
Urbano is offline
NEW FS: Radiator fluid, 190e- fuel filter/timing chain/timing chain tensioner ect Benznoob26 For Sale/Wanted/Trade/Giveaway 4 08-29-2010 11:31 PM
Boost Timing Master with Bosch EZL ignition? tomant W201 190-Class 0 07-16-2008 03:41 PM
Kat gone... suggestions? J.C. R129 SL-Class 11 11-30-2007 07:44 AM
EZL resistance timing plug zviratko W126 S,SE,SEC,SEL,SD,SDL Class 11 07-22-2007 09:44 AM
A kat question whiteyford C208/A208 CLK-Class 0 05-27-2003 12:29 AM
