86 SEL Cold Start Problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-08-2010, 12:28 PM Thread Starter
Date registered: Jan 2010
Vehicle: 86 560SEL
86 - 560SEL Cold Start Problem
I purchased an 86, 560 SEL with about 89000 miles from a family friend who has owned the vehicle for a number of years. It appears to be well maintained as there are no oil leaks and everything works. Well almost everything as there is a cold start issue that disappears after the first start of the day. I've hot-wired the cold start injector and it fires right up (stone cold engine) leading me to believe there is an electrical issue.
Having purchased the service manuals and following the trouble-shooting guide/wiring diagram, I have the following results: .5 volts to the cold start injector (should be at least 10v) and wiring between it and the N16/4 checks okay (including ground). Removing N16/4 and checking pin 12 indicates 12 volts, but pin 2 indicates 0 volts (according to the manual should have between 3-5 volts). Checking continuity between N16/4 and the Idle Speed Control relay (N8) is okay including its ground. Having no special tools other than a multi meter and some jumper wires, I am hesitant to replace the N8 relay due to its cost and not completely sure if I'm heading in the right direction.
Any ideas you folks have would be greatly appreciated..
Thanks
Rick
whyme2 is offline
post #2 of 3 (permalink) Old 02-08-2010, 03:00 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Try searching for "cold start" or asking on the W126 forum. That's what MB calls your chassis. Good luck and welcome to the forum.
Musikmann is offline
post #3 of 3 (permalink) Old 02-08-2010, 04:16 PM Thread Starter
Vehicle: 86 560SEL
Thanks
Rick
Thank you sir, I'll repost in the W126 forum...
whyme2 is offline
    1976 450 SEL hard cold start myk65 W116 S, SE, SEL, SD Class 6 01-27-2010 02:32 PM
    cold start problem Manvirg133 R129 SL-Class 6 01-15-2010 07:41 AM
    Cold start problem C180MB General Mercedes-Benz 3 08-24-2009 11:39 PM
    300 sel cold start issues Dusty`NZ W126 S,SE,SEC,SEL,SD,SDL Class 2 08-26-2005 09:57 PM
    Update on my cold start studdering problem - problem fixed? Douglas-Indianapolis R170 SLK-Class 4 04-25-2001 04:28 AM
