Code PO175...Help, Do I need a New Transmission? - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 02-08-2010, 12:58 PM Thread Starter
Date registered: Feb 2010
Vehicle: Mercedes S430
I have a 2001 S40. My car has been stuck in the snow and ice. While I was attempting to push the car out, my wife was revving the engine up kind of high trying to get out of the spot. Afterwards, the car cut off. Later on that evening, the car would not move in any gear as if it was in neutral. Sometime, I have to reatrt the car, then it will let me drive for about a block than go bak to slipping again, as if it's in neutral. While it is in drive, it won't even let me down shift gears 3, 2, or 1. The next day, I took the car to a local mechanic and the following code came up: PO715.
Question: Does this mean that I need a new transmission? Did she brun the transmission out by revving the engine up to high?
Also, although this may not be correlated, my power sterring pump went up as well while we were trying to get out of the snow.
Help!...Any information would be greatly appreciated.
amorehouseman is offline
post #2 of 16 (permalink) Old 02-08-2010, 01:11 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
Your power steering pump went up where?
flyboyike is offline
post #3 of 16 (permalink) Old 02-08-2010, 01:14 PM Thread Starter
The Power steering pump went up right after we've been trying to get out of the snow....when we were revving the engine up.
post #4 of 16 (permalink) Old 02-08-2010, 01:16 PM
flyboyike's Avatar
Quoted: 68 Post(s)
P0715 is input speed sensor malfunction, hardly means transmission failure.
post #5 of 16 (permalink) Old 02-08-2010, 01:22 PM Thread Starter
Shew, thanks!...But even if it's slipping? The codes stated something like, "Turbine/input shaft speed sensor a circuit. So, after replacing this sensor, everything will be okay? Is it something I can do or will the dealer have to do the service?
post #6 of 16 (permalink) Old 02-08-2010, 02:04 PM
flyboyike's Avatar
Quoted: 68 Post(s)
Went up where? Did the pump leave the engine compartment? What do you mean it went up?
post #7 of 16 (permalink) Old 02-08-2010, 02:12 PM Thread Starter
The power steering pump no loner works.
post #8 of 16 (permalink) Old 02-08-2010, 02:14 PM
flyboyike's Avatar
Quoted: 68 Post(s)
I see. Is it seized up or what?
post #9 of 16 (permalink) Old 02-08-2010, 02:15 PM Thread Starter
Yes, it's seized up.
post #10 of 16 (permalink) Old 02-08-2010, 02:21 PM
flyboyike's Avatar
Quoted: 68 Post(s)
Is there fluid in it?
    code P0715 transmission 1999 c230 kompressor W202 C-Class 7 04-11-2013 07:18 AM
    Help! Do I need a new transmission? Code PO715 amorehouseman W220 S-Class 7 02-08-2010 07:59 PM
    Transmission problem, code 148 coolkiminus W203 C-Class 0 01-21-2009 06:38 PM
    Threw Code 700 for the transmission Tweel W210 E-Class 6 04-04-2008 06:37 PM
    Radio code and transmission theory Peter Rich R170 SLK-Class 5 10-12-2006 10:11 PM
