Code PO175...Help, Do I need a New Transmission? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 02-08-2010, 01:22 PM Thread Starter
Date registered: Feb 2010
Vehicle: Mercedes S430
Originally Posted by flyboyike View Post
Is there fluid in it?
Yes
amorehouseman is offline
post #12 of 16 (permalink) Old 02-08-2010, 01:31 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
So, how are you driving it then, since I assume the belt can't move either what with the pump seized up?
flyboyike is offline
post #13 of 16 (permalink) Old 02-08-2010, 01:33 PM Thread Starter
I haven't been because the the car hardly moves. Maybe PS Pum and the the tranny is not correlated. My biggest concern is that PO715
post #14 of 16 (permalink) Old 02-08-2010, 04:38 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 383 Post(s)
Originally Posted by amorehouseman View Post
I have a 2001 S40. My car has been stuck in the snow and ice. While I was attempting to push the car out, my wife was revving the engine up kind of high trying to get out of the spot. Afterwards, the car cut off. Later on that evening, the car would not move in any gear as if it was in neutral. Sometime, I have to reatrt the car, then it will let me drive for about a block than go bak to slipping again, as if it's in neutral. While it is in drive, it won't even let me down shift gears 3, 2, or 1.
It sounds like you might be in Limp-home mode, which can happen with repeated wheel spinning (ie, in snow) You only have 2nd gear and reverse. The ETC module (N15/3) does this to prevent damage to the automatic transmission. I have read that if you switch off ESP (maybe in the US you cannot do that) it will not go into Limp-home mode. MB can reset your codes and clear it for you. ESP was discussed recently here:
http://www.benzworld.org/forums/gene...-turn-off.html
keyhole is online now
post #15 of 16 (permalink) Old 02-08-2010, 04:41 PM
Date registered: Nov 2006
COULD BE ONE OF A FEW THINGS. ITS VERRY POSSIBLE YOU BURNT UP A BAND IN THE TRANS OR tCU IS DEFECTIVE. GET SOME LUCAS FOR THE TRANS AND POUR IT IN BE CAREFULL NOT TO BREAK THE TRANS DIPSTICK PLUG IT SAYS WORKSHOP ONLY ON IT YOU CAN GET IT OFF YOURSELF BUT YOU MAY HAVE TO BREAK THE TAB ON IT. IF THE CAR IS SHIFTING BETTER YOU BROKE A BAND IN THE TRANS IT WILL BE EXPENCIVE YOUR BEST BET IS TO GET A USED TRANS ON EBAY ONES FROM MERCEDES WILL BE AROUND 5000
lodownlv is offline
post #16 of 16 (permalink) Old 02-08-2010, 05:17 PM
keyhole's Avatar
Quoted: 383 Post(s)
Do not do that ^^^^
    code P0715 transmission 1999 c230 kompressor W202 C-Class 7 04-11-2013 06:18 AM
    Help! Do I need a new transmission? Code PO715 amorehouseman W220 S-Class 7 02-08-2010 06:59 PM
    Transmission problem, code 148 coolkiminus W203 C-Class 0 01-21-2009 05:38 PM
    Threw Code 700 for the transmission Tweel W210 E-Class 6 04-04-2008 05:37 PM
    Radio code and transmission theory Peter Rich R170 SLK-Class 5 10-12-2006 09:11 PM
