Mirror and window issues - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-08-2010, 11:08 AM Thread Starter
Date registered: Feb 2010
Hi all, first post here.
I have a couple of issues with my drivers door mirror and window, and I'd appreciate any suggestions.
I have a 2003 ML 350 D.
The issues are:
(1) the mirror, when you retract it, does not stop and instead bangs off the door 4 or 5 times before coming to a stop.
(2) the window won't go up or down and slides down a few centimeters (over a few hours) when you put it up manually (ie with your hands not a handle!). The day that the window problem started there was a crunching sound (similar to stepping on broken glass) when I tried to put the window down.
I don't know if these problems are related, because the mirror has been like that for at least 2 years, while the window problem is new.
Many thanks.
MLme is offline
post #2 of 5 (permalink) Old 02-08-2010, 11:28 AM
Date registered: Oct 2008
Window issues
You need a new window regulator. When I tried to put the window down, I heard the crunching sound (similar to stepping on broken glass). Apparantly there are coils that get wound up and the glass crunches against it. Main dealer replaced regulator . Cost incl fitting £250. You must buy regulator from MB Main Dealer.
colonjp is offline
post #3 of 5 (permalink) Old 02-23-2010, 06:24 AM Thread Starter
Thanks for the tip. Forewarned is forearmed and all that .
MLme is offline
post #4 of 5 (permalink) Old 02-23-2010, 08:45 AM
Kajtek1's Avatar
Quoted: 1289 Post(s)
Those regulators are common issue on E class. You will find several pictorials in W210 section what might give you some ideas what to look for.
Bottom line, on E the part that commonly breaks can be bought for 7 to 9 dollars. No need to shave hundreds for new regulator.
Kajtek1 is online now
post #5 of 5 (permalink) Old 02-24-2010, 06:25 AM Thread Starter
Thanks
MLme is offline
Window Motors Issues pioneerniles W202 C-Class 1 02-21-2010 10:02 PM
trunk light and left/right mirror bulb issues lamboverticaldoors W220 S-Class 1 12-16-2009 09:39 PM
Window issues cougs_83 W210 E-Class 3 12-10-2009 10:40 PM
Need driver's mirror - compatibility issues Dimmuburger W124 E,CE,D,TD Class 4 01-21-2009 06:46 PM
Window issues NicCosta W126 S,SE,SEC,SEL,SD,SDL Class 4 05-12-2008 06:36 PM
