Aux cooling fan is staying on :s430 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-07-2010, 11:56 AM Thread Starter
Date registered: Feb 2010
I have a 2000 s430. The aux cooling fan is staying on after the car is off,draining the battery. Could this be a fan control unit or relay problem? Where do I locate them? This started after the rain. Thanks for any help.
kelbo is offline
post #2 of 3 (permalink) Old 02-08-2010, 08:05 PM Thread Starter
Can anyone help?
kelbo is offline
post #3 of 3 (permalink) Old 02-09-2010, 06:35 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
According to the WIS, I have identified this fault on another model, but it could be your reason also. For W208 (after 1997) with 113 engine.
Fault: Auxillary fan runs when engine is off.
Cause: "Water ingress in the fuse/relay box, via the housing cover, causes corrosion at the contact between the fuse and relay module, front passenger relay box (SRB) and the SAM."
So I would examine this area for any signs of corrosion, as it would seem that the cover is not totally waterproof. Here's a picture of the parts involved.
1. Clamping lever. 2. Fuse carrier. 3. Couplings. F1/1 Right fuse box. K40/7 Right front fuse & relay module. N10/7 Passenger side SAM control module.
Name:	W220 front SAM.jpg
keyhole is online now
    Aux cooling fan not coming on 560sjw W126 S,SE,SEC,SEL,SD,SDL Class 4 05-22-2009 10:21 PM
    190e Aux Cooling Fan Replacement - ?? soltek W201 190-Class 7 09-20-2008 07:07 PM
    For Sale:: Aux Cooling Fan for '92 190e 2.3-8 soltek W201 190-Class 7 09-12-2008 02:52 PM
    Aux. - Cooling Fan allways on ... MRBSMITH W210 E-Class 8 07-22-2008 11:04 AM
    aux fan/cooling fan m4411b W201 190-Class 12 03-06-2006 08:00 AM
