Oh crap, what did I do? Reset Service Indicator... - Page 3 - Mercedes-Benz Forum
post #21 of 30 (permalink) Old 02-08-2010, 09:42 AM Thread Starter
Mercedes_Maniac's Avatar
Date registered: Nov 2008
Vehicle: 2006 - CLK 350 (coupe)
Wink
Gulp!
Thaaaaank you!
Originally Posted by eric242340 View Post
So here are a few for reference, or you can always google it
4MATIC Automatically controlled four-wheel drive AAC Automatic air conditioning AAM All activity module A/C Air conditioning (Automatic) A/C Air conditioning (Tempmatic) AB Airbag ABS Anti-lock brake system ACSR Automatic child seat recognition ADM Automatic dimming inside rearview mirror ADS Adaptive damping system AIR Secondary air injection AP Accelerator pedal APS Auto pilot system AS Antenna systems ASD Automatic locking differential ASR Acceleration slip regulation AT Automatic transmission ATA Anti-theft alarm BA Backup assist BARO Barometric pressure BCAPC Barometric pressure-charge air pressure compensation BDC Bottom dead center BM Base module BPC Barometric pressure compensation CA Closing assist CAN Controller area network CC Cruise control CCM Combination control module CDC CD changer CF Convenience feature CFI Continuous fuel injection (electronic) CFI Continuous fuel injection (mechanical) CKA Crank angle CKP Crankshaft position CL Central locking CMP Camshaft position CNS Communication and navigation system CST Cabriolet soft top CTEL Cellular telephone CTP Closed throttle position (idle) CTU Central triggering unit DAS Drive authorization system DI Distributor ignition DM Diagnostic module DSV Drive authorization system shut-off valve DTC Diagnostic trouble code EA Electronic accelerator EBR Engine braking regulation ECL Engine coolant level ECT Engine coolant temperature EDC Electronic diesel control EDR Electronic diesel regulation EDS Electronic diesel system EGR Exhaust gas recirculation EI Electronic Ignition system (distributor-less) EL Exterior lighting EMSC Electric mirror, steering column adjustment, heated mirrors EPC Electronic power control ESA Electric seat adjustment ESC Electric steering column adjustment ESCM Engine systems control module ESP Electronic stability program ETC Electronic transmission control ETR Emergency tensioning retractor ETS Electronic traction system EVAP Evaporative emission control system FAN Fanfare horns FFS Frame floor system FOM Folding outside mirrors FP Fuel pump GIM Governor impulse method HCS Headlamp cleaning system HFM-SFI HFM sequential multiport fuel injection/ignition HFS Hands-free system HHT Hand-Held Tester HM Heated mirrors HORN Horn signal system HS Heated seats IAT Intake air temperature IC Instrument cluster IDC In-dash controller IFI In-line fuel injection IL Interior lighting IR Infrared IRM Inside rearview mirror ISC Idle speed control KS Knock sensor KSS Knock sensor system LCP Lower control panel LH-SFI LH sequential multiport fuel injection LHS Lefthand steering LOC Low compression LS Loudspeaker system MAF Mass air flow MAP Manifold absolute pressure ME-SFI ME sequential multiport fuel injection/ignition system MIL Malfunction indicator lamp MSC Mirror, steering column adjustment, heated mirrors MT Manual transmission MVA Manifold vacuum assist MWH Main wiring harness NS Networked Systems (CAN) O2S Oxygen sensor OBD On board diagnostics OC Oxidation catalytic converter OCP Over-head control panel ORM Outside rearview mirror OSB Multi-contour/Orthopedic seat backrest PL Power locking PMP Partial intake manifold preheater PNP Park neutral position PS Power steering PSE Pneumatic system equipment PIS Parktronic system PW Power windows PWM Pulse width modulation RB Roll bar RCL Remote central locking RD Radio REST Residual engine heat utilization RH Retractable hardtop RHR Retractable rear head restraints RHS Righthand steering RPM Engine speed RSI Roadster soft top RIG Retractable trunk lid grip RTR Remote trunk release RWD Rear window defroster SBE Seat belt extender SLO Starter lock-out SMS Service microfiche system SOR Seat occupied recognition SPS Speed-sensitive power steering SR Sliding/pop-up roof SRS Supplemental restraint system TB Throttle body TC Transfer case TCM Transmission control module TD Speed signal (time division) (EZL) TDC Top dead center TIC Transistorized ignition control TN Speed signal (EZL/AKR) TPC Tire pressure control TRAP Trap oxidizer TWC Three way catalytic converter VAF Volume air flow VSS Vehicle speed signal WS Wiper system WOT Wide open throttle (full load)
Mercedes_Maniac is offline
post #22 of 30 (permalink) Old 02-08-2010, 10:00 AM Thread Starter
I DID IT! After days and days of reading StarTek and so many attempts I finally did it. What was odd was that I did it without half of the things the directions said I should see. Either way finally! Thanks guys!
post #23 of 30 (permalink) Old 02-08-2010, 10:12 AM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Where's the beer?
Kajtek1 is online now
post #24 of 30 (permalink) Old 02-08-2010, 10:50 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Acronyms
Originally Posted by Mercedes_Maniac View Post
Thank you for your patience. By chance is there a thread that breaks down the acronyms? I wasn't able to find one when I did a search.
You're quite welcome but Eric did a much better job! When I come across one I don't know I use the search function for "acronyms". A thread will pop up on the W163 ML-Class forums that lists quite a few of them in alphabetical order. Congrats on your service reminder re-set.
http://www.benzworld.org/forums/w163...-acronyms.html
Musikmann is offline
post #25 of 30 (permalink) Old 02-08-2010, 10:59 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by Kajtek1 View Post
Where's the beer?
Polish or German?
post #26 of 30 (permalink) Old 02-08-2010, 03:13 PM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 386 Post(s)
But here is something that I saw before "Settings....To reset press reset button for 3 seconds", so I did and then this came up "Settings....Reset to factory settings? To confirm press reset button". I chickened out and didn't want to press that.
What does it mean by reset to factory settings?
Welcome to the forum. Just to clear up one question on your original post...
Your Owner's Manual should describe the multifunction displays and how to use them with the buttons on the steering wheel. You have options for many of the settings - eg, distance in miles or km, temperature in F or C, and various convenience & lighting options. These can be set up to the driver's preference, and saved in the ignition key memory. This can be different for 2 different keys (his & hers settings) provided you have the feature.
If you had continued to 'manufacturers default settings' these options might have changed. You can always re-set to your own preference.
keyhole is offline
post #27 of 30 (permalink) Old 02-08-2010, 05:43 PM
Kajtek1's Avatar
Originally Posted by Musikmann View Post
Polish or German?
anything but Bud.
post #28 of 30 (permalink) Old 02-08-2010, 05:52 PM
Musikmann's Avatar
Quoted: 6 Post(s)
anything but Bud.
We agree that regular American made Budweiser is garbage. European is better wherever it is made. Michelob is not too bad if you can find it on draft.
post #29 of 30 (permalink) Old 02-08-2010, 06:23 PM
Kajtek1's Avatar
For New Year party on Las Vegas Strip the Police close the street to vehicle traffic and don't allow glass there. There are beer stands that sell beer in plastic bottles (!).
The only available this year was Budweiser, when in the past they also had Miller.
Saying that I am perfectly happy with my accommodation only 200 yards from the Strip + elevator
post #30 of 30 (permalink) Old 02-09-2010, 08:22 AM
Musikmann's Avatar
Quoted: 6 Post(s)
That sounds a little like Mardi Gras in New Orleans. Nice city, or was, years ago. I haven't been there for a long time and that's not the best time to see it.
    Service indicator reset markbaumel@yahoo.com W211 E-Class 21 02-25-2016 12:18 AM
    How do I reset the service indicator? vladee W163 M-Class 37 12-16-2015 08:19 AM
    Reset service indicator mikefili W204 C-Class 12 07-27-2014 12:30 PM
    service indicator reset 7kviper W210 E-Class 2 05-19-2009 11:36 AM
    how to reset the service indicator vinceching W140 S-Class 2 04-20-2004 11:43 PM
