Electronic throttle control vs mechanical linkage, which models use what? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 02-06-2010, 10:17 PM Thread Starter
Date registered: Apr 2006
Vehicle: Vehicle Not Found
Quoted: 6 Post(s)
I've only ever driven autos with a mechanical linkage, but I plan on buying a 2007+ 211 in the near future. Can anyone let me know which mercedes models don't use mechanical linkages anymore? After seeing that most new toyota's use electronic modules, I'm shocked. I honestly didn't think any car used an electronic regulator, and I thought mercedes' great failure with SBC was as far as electronic throttle/brake inputs got.
Can anyone run down a list of current models with actual mechanical linkages?
DubVBenz is offline
post #2 of 7 (permalink) Old 02-06-2010, 11:15 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
As far as I know all Mercedes sold in last decade plus in US are drive_by_the_wire.
Don't worry >>> they are not Toyota
Kajtek1 is offline
post #3 of 7 (permalink) Old 02-06-2010, 11:27 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
None today would use a mechanical linkage. I doubt you can find any decent modern car that would use full mechanical throttle linkage. How do you control the engine ECU mechanically? You could do it for the throttle valve but not the injection, be it diesel or gasoline injection.
The Toyota issue was mechanical (mostly). The gas pedal got locked mechanically and this will be fixed by inserting a metal plate that allows more room for the mechanical parts to move and not get stuck even after some wear (as is happening now). You would have mostly the same problematic parts even if the throttle linkage was mechanical.
Unfortunately we cannot have the control made fully electronic to avoid these Toyota problems. It is a lot more common to have the Lexus/Toyota issue on old cars where the wire from the mechanical linkage wears and gas pedal gets stuck on full throttle.
And SBC brakes were no disaster. Well, there were more than one fix for the wiring harness etc. that were essential but how many complaints have
you seen lately while a huge number or cars are in use? All of the owners of a car with SBC brakes appear to be happy with the very powerful system with new features like SBC Hold and SBC Stop that did not exist previously. Excluding a few owners who faced the issues before all the recall work took care of this, it is only those who do not have a car with SBC brakes that find it a disaster. This of course is a big issue for the MB sales and marketing department and one significant reason why SBC brakes were discontinued.
If you really want to avoid the risk you are afraid, you should immediately change your current car to a modern MB with an electronic throttle control.
Diesel Benz is offline
post #4 of 7 (permalink) Old 02-07-2010, 09:19 AM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 391 Post(s)
The w210 series (96 on) use drive by wire for the throttle. To my knowlege so do all other mercedes models from at least 2000, most from the mid 90's on.
So does my 04 Silverado. I'd bet that there isn't a new car sold in the U.S. today that doesn't have a drive by wire throttle. And I'd bet that well over 90% of any cars from about 2000 on are drive by wire.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is online now
post #5 of 7 (permalink) Old 02-07-2010, 10:51 AM
Kajtek1's Avatar
Per news articles -Toyota switched to DBW around 2003.
So maybe 2002 Toyota is what OP seeks?
Kajtek1 is offline
post #6 of 7 (permalink) Old 02-07-2010, 11:31 AM Thread Starter
Quoted: 6 Post(s)
Wow, goes to show how much I know about modern cars...
DubVBenz is offline
post #7 of 7 (permalink) Old 02-07-2010, 11:46 AM
Kajtek1's Avatar
Hey, do you still have that crank-operated calculator?
Kajtek1 is offline
    Electronic Throttle Control Module needed urgently El Prez W140 S-Class 14 08-28-2012 09:57 AM
    Throttle Linkage fodorizzi W203 C-Class 8 04-08-2009 11:40 PM
    Throttle Linkage Weather Man R/C107 SL/SLC Class 2 03-06-2009 07:54 AM
    Can I convert wired throttle to electronic throttle? eddietham R170 SLK-Class 12 03-25-2007 12:45 PM
    throttle linkage elgatoensombrero W123 E,CE,D,CD,TD,TE Class 3 01-25-2006 10:40 PM
