190E No warm start - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-06-2010, 04:31 PM Thread Starter
Date registered: Nov 2009
Vehicle: 95 C280
Question 190E No warm start
89 190E 2.6 nothing has help so far this car will fire up and run good when the motor is cold but it run for 10 min and stall out then won't restart till the next day I try cleaning the plugs they get a black soot and smell like gas after that one run also check it is getting good spark after it stall.
replace the Temp sensor, Ovp. Fuel pump relay Clean EHV, Fuel filter ,Fuel Pressure Regulator,ICV. nothing is helping what do I check next ?
yanceycat is offline
post #2 of 3 (permalink) Old 02-07-2010, 10:24 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
You have leaking fuel injectors that are flooding the motor.
Press accel pedal down some when cranking to confirm.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 3 (permalink) Old 01-07-2013, 02:32 PM
Date registered: Dec 2009
Vehicle: 1989 W126, 300SEL
Perhaps a new oxygen sensor would help?
crickle is offline
    190E 2.6 warm start problems kevinbentley W201 190-Class 27 04-19-2016 03:49 AM
    No Warm Start yanceycat W201 190-Class 4 12-28-2009 01:58 PM
    Hard Start when warm banyan W126 S,SE,SEC,SEL,SD,SDL Class 4 07-15-2008 06:43 PM
    Difficult warm start raftel W116 S, SE, SEL, SD Class 2 01-11-2006 09:12 AM
    Hard start or second start when warm high hc level-- beware major expense Peter Seow W126 S,SE,SEC,SEL,SD,SDL Class 1 07-03-2004 06:23 PM
