Oil Removal From Top Of Engine - Mercedes-Benz Forum
post #1 of 21 (permalink) Old 02-04-2010, 04:47 PM Thread Starter
Date registered: Feb 2010
Has anyone who removed oil from the top of their engine gone to the trouble of draining the pan afterward to see how much oil was left?
I have done several vehicles like this in the past when I know I am only leaving a few drops of oil in the pan. Works better on some cars then others.
zgreatwhite is offline
post #2 of 21 (permalink) Old 02-04-2010, 07:02 PM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Considering you usually have to get under the car to change the oil filter (your dumb if you don't change it). Why go through the hassle of sucking the oil out instead of the "tedious" labor of loosening a bolt?
tgikal is offline
post #3 of 21 (permalink) Old 02-04-2010, 07:17 PM
Kajtek1's Avatar
Quoted: 1227 Post(s)
You guys are on wrong forum. All Mercedes have top mounted filters and dipstick tubes design for extraction.
Kajtek1 is online now
post #4 of 21 (permalink) Old 02-04-2010, 08:09 PM
Date registered: Jul 2004
Quoted: 316 Post(s)
They also all have drain plugs designed for draining too. The OP has asked a legitimate question.
deanyel is offline
post #5 of 21 (permalink) Old 02-04-2010, 08:48 PM
Kajtek1's Avatar
Living back in communism -The Party required chief executives to volunteer once a year into community work like planting the trees.
They had only one instruction how to do it
"Green side up"
Mercedes are design for top oil extraction for at least 2 decades. The drain plug is only as a backup and on newer model it takes like 20 minutes to get to it.
post #6 of 21 (permalink) Old 02-04-2010, 09:06 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 387 Post(s)
"Green side up"
Don't know about the latest cars, but on my 97 E420, (which isn't two decades old) it takes <5 minutes to get to the drain plug, and with a fumoto valve, 1/4 turn and oil is draining. The way he 420 pan is designed, I can get every last drop out even with the front end on ramps. Supposedly that isn't the case on some of the newer models. While it is draining, I replace the oil filter (which takes far longer than getting to the drain plug BTW) check under the engine then fill. I'll bet it takes no more time, and probably less time and effort than topside extraction. Gives an reason to do a good underside inspection as well, which one should do anyway. And I need one less space occuping tool (topside extractor)
BTW, if you do use the drain plug, get a fumoto valve. I've used them on all my recent cars and makes oil changing much easier, no muss, no fuss, no runs, no drips.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #7 of 21 (permalink) Old 02-04-2010, 11:15 PM Thread Starter
Wow...where do I start.
First, please rest assured I will always replace the oil filter with a new oil filter. More than likely go with the MOBIL 1 filter, definitely with MOBIL 1 oil. But let's not get into a discussion of filters and oil.
The 2009 CLK350 Cabrio is my family's first offshore vehicle. I understand my model of MB was designed for "FROM THE TOP" oil changes. I just wondered if anyone has gone to the trouble of seeing what was left in the pan. If not, well then I will find out in 8 months or so when I get to my first oil change.
post #8 of 21 (permalink) Old 02-05-2010, 08:27 AM
Kajtek1's Avatar
I did the test on ML55 and E300TD.
Depends on the timing you will always get couple of spoons switching from one method to the other. It takes pretty long time for the oil from upper engine shelf, coolers and so on -to get down to the oil pan. Meaning even after pulling the plug and fully draining the pan -I was still able to gargle some oil with the dipstick suction.
No matter what you do -at least a cup of oil will be always trapped in the engine.
post #9 of 21 (permalink) Old 02-05-2010, 12:16 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Originally Posted by zgreatwhite View Post
...More than likely go with the MOBIL 1 filter, definitely with MOBIL 1 oil...
If your car requires it, just make sure the Mobil1 filter is the fleece type.
Musikmann is offline
post #10 of 21 (permalink) Old 02-05-2010, 05:24 PM
Quoted: 316 Post(s)
It's clear that you're capable of imaging this but can you show it - in an official document that says oil is not to be drained from the bottom? I'm ready to be convinced but all I ever see is forum pontification on the subject.
deanyel is offline
    PUDDLE OF OIL! on top of plastic under engine guard. sightless R170 SLK-Class 7 07-16-2009 01:25 AM
    Engine plastic top cover removal funnyguy1 General Mercedes-Benz 1 06-24-2007 01:14 PM
    Engine plastic top cover removal funnyguy1 General Mercedes-Benz 2 06-24-2007 11:37 AM
    Weird oil leak from top of engine?? 240DieselPower W123 E,CE,D,CD,TD,TE Class 11 04-14-2007 12:44 AM
    Oil Cooler Hose Removal from the top. Winston W123 E,CE,D,CD,TD,TE Class 0 12-15-2006 10:50 PM
