UK GPS Sat Nav location problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-03-2010, 06:28 AM Thread Starter
Date registered: Apr 2009
Hi, I am new to this forum but hopefully someone can help me with my problem.
I have a UK 2004 E class and have a problem with the sat nav. The marker on the command unit is showing the location of the car in the wrong place (aprrox 30miles north of where I actually am).
When the car is moving the marker does move but it is moving on the map 30miles away and makes no sense.
Anybody have an idea what the problem could be?
I have been using a 2009 disc which worked fine for 6 months.
Thanks
G
gurda is offline
post #2 of 4 (permalink) Old 02-03-2010, 08:55 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
I'm not going to be much help to you. (but I also have a 2004 MB with a factory fitted COMAND SatNav system in the UK. I am still using the original Nav CD supplied with the car, so it is now a bit out of date with some new roads. (not many, in practice)
Just now and again the display gets totally screwed up, and shows an area miles from where I actually am. Also it sometimes displays the number of satellites in view. Mostly it doesn't. It seems to correct itself.
If the co-ordinates are being incorrectly calculated, it must be an erratic s/w or hardware problem in the COMAND unit. Mine is not frequent enough to bother me, as I do not use the system enough to matter.
keyhole is offline
post #3 of 4 (permalink) Old 02-03-2010, 09:37 AM
Diesel Benz's Avatar
Quoted: 37 Post(s)
If it shows consistently a wrong location and the map seems to move as the car moves, then it must be a bad GPS antenna and the navi processor is working with gyros and speed signal. How many satellites does it report? Probably "0" or "-".
A lot of info on this at the W211 forum.
Diesel Benz is offline
post #4 of 4 (permalink) Old 11-04-2010, 04:31 AM
Date registered: Nov 2010
I have a 2004 E Class and just resolved this problem....
My system was reporting "0" satellites. I purchased a new GPS antenna with blue fakra plug from ebay for $15 and problem fixed.
I mounted the new antenna under the rear parcel shelf.
Slick320 is offline
    COMAND Sat Nav problem - help please Rodge Audio & Telematics Forum 2 05-09-2009 06:02 AM
    GPS misreading on Sat Nav display. pjas1969 Audio & Telematics Forum 6 12-19-2008 07:49 AM
    Newbie Alert!! - Have Sat Nav Problem aabedi General Mercedes-Benz 5 05-26-2008 02:52 PM
    VSS and Reverse wire location for sat nav install. BIG 500SEC W140 S-Class 0 02-02-2008 12:11 PM
    Sat Nav voice problem P18TRG R171 SLK-Class 16 04-14-2006 08:11 PM
