2007 C280 Engine replacement - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-01-2010, 03:08 PM Thread Starter
Date registered: Feb 2010
Vehicle: 2007 C280
I have recently purchased a 2007 C280 RWD that needs an engine. (current one has a hole in the block).
I have a few questions I need help with:
1-Can i use the 4matic engine in a RDW car or do I have to find a RWD C280?
2-What years will fit the 2007 C280.
3- Any ideas on where to find one at a reasonable price?
4- Is there anything trciky I should know about swapping the engines when I do it? ( I am backyard mechanic at best but have done a few engine swaps on some much easier and basic American cars)
Any advice would be greatly appreciated!
larlam is offline
post #2 of 3 (permalink) Old 02-01-2010, 03:15 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
I hope you knew that the engine was shot before you got the car. How exactly did a hole get into the block of a 3 year old car? If the rest of the car is beat up and a mess, then just part it out. It isn't worth putting that kind of money into a car that isn't worth much to begin with.
mr.xpowerseller is offline
post #3 of 3 (permalink) Old 02-02-2010, 02:15 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi larlam,
you should realsie that swapping the physical engine block is the least of the job! The electronics will be a major hassle! I suggest you look for an engine and transmission and all the electronics and wiring which goes with them.
You have to get the ECU (Engine Control Unit) box, the unit that the key goes into, the wiring between them, and the transmission lelectronics are they are all coded to work together, and won't work separately. Then there is the ESP (Electronic Stability Protection) module, which also needs to know what engine it has to work with (weight, power, torque etc) so that it can control the car in extremis.
I think the previous advice about using it for a parts car is sensible.
good luck
Audiophile_AU is offline
    2007 C280 4 Matic TomKruc General Mercedes-Benz 2 08-08-2009 03:03 PM
    2007 c280 4matic AJCBenz W203 C-Class 7 08-05-2009 03:04 PM
    2007 C280 Parts HELP!! xiash W203 C-Class 7 03-20-2009 06:03 PM
    1998 C280 Engine Mount Replacement JHL216 W202 C-Class 3 01-31-2009 09:25 PM
    Just got my 2007 c280 4matic ladyb81 General Mercedes-Benz 2 12-05-2008 04:44 PM
