gearbox fault code 017/013 selector lever - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-30-2010, 12:43 PM Thread Starter
Date registered: Jan 2010
Vehicle: Mercedes CLK 230 K
Hi everyone,
I have an ongoing problem with my 99 c230k which likes to pop into limp mode when it feels like it and gets stuck in 2nd gear.
i will update the original thread in the 208 section once i get to the bottom of the fault.
but for now, can anyone shed any light on the following fault codes i have:
013 SELECTOR LEVER CODING INVALID
017 SELECTOR LEVER CODING INVALID
codes were read on a snap-on solus pro, and then deleted, car was fine for a couple of hours (stop/start driving) but then decided it was happier in limp mode.
I am assuming this is a fault with the selector mechanism rather than the gearbox itself? is there a switch/sensor in there that would trigger this fault that needs replacing?
someone has mentioned that i can adjust the selector??? does this mean lining up drive/park etc on the selector with drive/park etc on the gearbox? because this all appears to be ok (when i select reverse for example on the selector it selects it perfectly ok in the gearbox)
any help would be appreciated.
awiserbud is offline
post #2 of 3 (permalink) Old 01-30-2010, 12:45 PM Thread Starter
sorry, car should have read CLK230K, not c230k
post #3 of 3 (permalink) Old 02-03-2010, 01:14 PM Thread Starter
thanks for all your help guys....looks like i'm on my own with this one!
i'll do what less resourcefull people do, just throw parts at it until the problem goes away!
    Selector-lever position - should be illuminated brightly? [PL]Camel- W202 C-Class 3 11-15-2009 11:16 AM
    selector lever in Park ices C219 CLS-Class 7 05-23-2009 12:41 PM
    Where can I buy a transmission selector lever for 87 300td dougjester W124 E,CE,D,TD Class 1 11-06-2008 02:36 AM
    clock & selector lever position display carZone W210 E-Class 2 04-24-2007 11:10 AM
    selector lever display stewedg R129 SL-Class 2 05-18-2005 12:51 AM
