Mercedes e320 front passenger tire noise - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-27-2010, 01:21 PM Thread Starter
Date registered: Oct 2005
Vehicle: 2000 ML430
I have been experiencing on usual sound when driving from the passenger side.
I changed the tires on my car but sound still persist.
Wheel bearings were checked sometime back by a mechanic.
The dealer states the car has the wrong tires on. Any recommendation on tires(quiet) for this car willl be very appreciative.
Thanks,
JB
kwebu is offline
post #2 of 3 (permalink) Old 01-27-2010, 01:30 PM
Kajtek1's Avatar
Quoted: 1191 Post(s)
Some tires can be way noisier than the others. I prefer Michelin.
When we changed the tires on ML320 from original General to Eagle the noise level drop was quite noticeable.
Kajtek1 is online now
post #3 of 3 (permalink) Old 01-27-2010, 05:27 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Noise from only one side is probably not due to the brand of the tire, or the size as long as they are the same. Does it also pull in that direction? Or do you feel any vibration in the seats or steering wheel? Whether it does either of these or not, tires can just go bad after driving for some time. Plus I had a bad wheel bearing and one "good" shop missed it so don't rule that out.
Musikmann is offline
    Noise from front passenger wheel theyaa W163 M-Class 10 08-22-2011 06:05 PM
    (update) sound in front passenger side tire brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 1 07-25-2007 03:31 AM
    E320 oil leak front passenger side ksing44 W124 E,CE,D,TD Class 9 02-07-2006 12:49 AM
    Found the source of the "noise" FRONT PASSENGER SIDE gsj224 W163 M-Class 1 12-19-2005 01:06 PM
    2004 G55 - Front Passenger Door Noise wavelengths G-Class 15 06-11-2004 07:33 PM
