1987 4230SEL starts, dies - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 01-24-2010, 09:42 AM Thread Starter
waybomb's Avatar
Date registered: Apr 2005
Vehicle: 2005 S55; 2003 ML350; 2002 C240; 1997 C280 Sport; 1991 300SL; 1986 190e 2.3 16V (2); 1968 W30 442
Quoted: 7 Post(s)
I started a thread in the 126 section, but I believe the same problem could occur on any 87 gas Benz, and am still looking for a solution. Here's my last post in the 126 section....
This is my kid's car. Here's the entire serious of checks and the symptoms. I haven't worked on the car at all; I got all my info from Kev, my son.
The first thing I told him to check was the fuel filter. He did, and it was partially clogged. he replaced it.
He then told me no fuel was coming out of the tank. I told him to look at the repair cd's to make sure he was looking at the correct line. He's too smart to do that, so he pulls the tank. It was clean, the screen was clean, he was checking at the fuel filter outlet. The line coming from the tank flows fuel freely.
I am sure this is not a fuel problem.
He had the car at a buddy's shop. They put a real battery load tester on the battery and it failed miserably. Replace battery. Thats seemed to help. He went to pick up the car and a block away from the shop, the car dies again.
They test the alternator. It is marginal. They replace the marginal alternator. Seems fine, until he drives away.
So now I get involved and visit the place he has the car.
here's how it goes:
Cold start, fires right up, idles fine, and at around 50c coolant temperature or so, the idle jumps up to about 2200 rpm or so. It runs like this for anywhere from 15-45 seconds, then abruptly shuts off. It doesn't spool down slowly; it shuts off.
If restarted immediately, it jumps up in rpm almost bright away, and dies after about 15 seconds.
While in this process of dying, I sprayed started fluid into the air valve. The engine did not pick up at all in RPMs and died. So, something electrical.
What could cause the engine to shut down electrically AND cause the rpms to jump up for 15-45 seconds? Does anybody here have the suspect controller we could borrow and try out, and then buy if needed?
If after the first event, the car is allowed to cool down, it takes longer for the process to occur. So, somehow, this is related to coolant temperatureas well.
He had a known good OVP and tried it. Nope.
What do you think the issue could be? I am not around to help him, but I'd like to save him some money. He's going to tow it to a Euro-car repair place. I can just see the $$ racking up and he doesn't save money like kids should.
2005 S55
2003 ML350
2002 C240
1997 C280 Sport
1991 300SL
1968 W30 442
1988 46' Cougar US1 with Triple blown 572s
Warming the Globe, 24 Cylinders at a Time
Point me to a 126 wagon in the States PLEASE!
waybomb is offline
    Buying a 1987 190E 2.3, Car Starts then Dies NTL1991 W201 190-Class 4 08-14-2009 01:49 PM
    starts then dies glenn1 W202 C-Class 23 04-21-2009 09:04 PM
    Help! Starts normally then dies! Xmodius W126 S,SE,SEC,SEL,SD,SDL Class 21 08-14-2007 08:22 PM
    Starts, then dies 190E_goon W201 190-Class 0 12-13-2005 11:24 AM
    280E Starts and Dies, starts and dies.... GermanCarNut W123 E,CE,D,CD,TD,TE Class 3 02-07-2004 07:28 PM
