2003-2006 ML350 Wiring Diagram - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 01-21-2010, 08:50 AM Thread Starter
Date registered: Dec 2009
Vehicle: ML350 04', ML 320 00', G-460 86'
Send a message via Skype™ to nilstores
Can someone share the wiring diagram if one is available.
nilstores is offline
post #2 of 10 (permalink) Old 01-21-2010, 08:54 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 882 Post(s)
The wiring diagram for what? You must be specific.
43sqd is offline
post #3 of 10 (permalink) Old 01-21-2010, 09:05 AM Thread Starter
The electrical wiring diagram, mainly between ecu - engine sensors - autotransmission brain box - gear lever - immobilizer unit - body unit.
post #4 of 10 (permalink) Old 01-21-2010, 12:48 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
I doubt anyone is willing to print all that info to you. You have to be more specific like 43sqd mentioned. Or buy a service DVD and you can have all the info you need.
Diesel Benz is offline
post #5 of 10 (permalink) Old 01-21-2010, 12:53 PM Thread Starter
Where can I buy/download a service dvd?
post #6 of 10 (permalink) Old 01-21-2010, 01:39 PM
Quoted: 35 Post(s)
Where are you from (would be useful to add the location to your profile)? US owners can buy one cheap from MBUSA.
post #7 of 10 (permalink) Old 01-22-2010, 06:15 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 375 Post(s)
These cars do not have 'wiring' as such. Modules exchange data via CAN bus A, B & C. Sensors connect to the appropriate module.
keyhole is online now
post #8 of 10 (permalink) Old 01-22-2010, 08:23 AM Thread Starter
I'm fully aware of this, but CAN bus is also dependent of wires The thing is that I try to get a M112 engine running in my car project. And I need to know the pinout for the brain boxes as I'm removing them from a wrecked car. I'm trying to use as few black boxes, sensors,lamps and actuators as possible. Anyway I've got a wiring schema for a slk 320, and I guess it will work for know.
I'll be happy if anyone who has expirence of doing this, or has some knowledge about this will answere me. So the question is what is the absolute minimum of electrical components you need to get a engine+autotrans from a ml350 2004 up running?
post #9 of 10 (permalink) Old 01-22-2010, 09:00 AM
Quoted: 35 Post(s)
Interesting project. You would definitely need your own copy of WIS or on-line access to WIS, you cannot rely on data from a forum. Too many details that you have to look after.
Perhaps you will be able to answer your question later on, remember to come back when you are ready.
If you want the engine and the transmission to work, including the gear stick etc. I think the question would be more like "which control units are not needed". You should be safe to leave all entertainment units out, even cluster and ESP/ABS etc. but in addition to the EIS, the engine ECU, the TCU and the lower control panel control unit (car dependent), front SAM but others may be needed too.
post #10 of 10 (permalink) Old 01-22-2010, 10:33 AM Thread Starter
Sure, when I get engine running, I'll share the information with the forum. One approach is to move everything to the new car and then remove module after module, but it is a couple of km of wire in there
    2003 CLK320 Wiring diagram--4 remote start lawrencecar1 C208/A208 CLK-Class 3 03-13-2009 03:16 AM
    wiring diagram 03 ML350 Fuel system basharv W163 M-Class 8 02-09-2009 08:37 AM
    Wiring diagram 413CDI Sprinter 2003 mikejeffery W901-905 Sprinter 1 10-21-2004 10:05 PM
    Wiring Diagram (or at least a radio wiring diagram) for ML320 yawstring W163 M-Class 3 07-02-2003 06:12 PM
    2003 ML350 Bi-Xenon Upgrade and Wiring Diagrams tobyp W163 M-Class 18 01-25-2003 01:01 PM
